Only light production work, no.Would I be mad to change a 3900x for a 5800x? I'm only doing light production work so the extra cores are not needed?
Gaming, maybe -
What's the likely performance uplift from all the tweaking compared to dropping the CPU in and setting a XMP profile? Are the gains worth the time invested?
In AMD world, leaving CPU stock and memory XMP, you will mostly be in a good position.What's the likely performance uplift from all the tweaking compared to dropping the CPU in and setting a XMP profile? Are the gains worth the time invested?
If you're currently using the 3900X then I'd just go for a 5900X or maybe wait for the summer refresh.Interesting. @1440, there is not much of a diff. The problem I have, I want to play with new kit.
I'm was getting 81c max with the wraith prism at stock setting although now with the CPU tuned up it maxes out at around 70c.What sort of temperatures are people getting on the 5800X using air cooling?
I've heard it runs very hot?
I've got a 5600X running on a Noctua NH-U12 which stays around 30*C idle and around 55*C load.
If I change it to the 5800X what sort of temperatures can I expect with the Noctua?
Thanks
76c max when heavy benching (AIDA64 stability testing) using manual PBO limits.What sort of temperatures are people getting on the 5800X using air cooling?
Thanks
16GB is fine...
Thanks
Running my 5600x with a B450 Tomahawk (non max) and no issuesAnyone have any first hand experience running the 5000 series on a B450 board? Any issues etc? Wondering how well the B450s are supporting the 5000 series.
