Don
- 20 Oct 2002
- Oxfordshire / Bucks
have fun, graphics are good
let us know how you get on
they usually dont, when you order new glasses, then they take your PD
Thanks, that will be why then.
Just sucks that the opticians are in a different city so means couple hours round trip or paying for another eye test closer to home just to measure my PD![]()
Surely you can measure it yourself with the ifone app or similar?
New quest 2 owner here.
I bought the official link cable and wanted to try a PC game but I think something isn’t quite right as the resolution is not sharp enough. In project cars 2, the in game resolution will match my actual monitor and not the quest. Is this a problem?
other than that, thoroughly enjoying the system!
Quest 2 with link here, running 500 bitrate and 1.5ss and for the most part runs fine but I'm still getting occassional stutters / audio drops outs every now and again.
Anyone experiencing the same or have a fix? I've tried setting the process to realtime etc but doesn't really do much.
It'll never be as sharp as your monitor, as you're putting a 4k screen right up to your eyes essentially, so the angular resolution is much less.
That said, you can alter the quality of the image (essentially the resolution or super-sampling) in the oculus app settings, but higher quality is much more demanding and you may not be able to sustain a playable frame-rate, particually in games like Project Cars 2 which are demanding anyway.
Is your signature correct and you have a 3080? Then you should open Oculus Debug tool and change the Encode Bitrate to 300. The Debug tool is found by going into the Oculus folder on your PC. Then into Support and Oculus Diagnostics. It starts a program where you can edit some variables for the headset. Look for "Encode Bitrate(Mbps)" and change the value to 300. Leave everything else at default.
Then start your Oculus App on your PC. Go to Devices. Click on "Quest and Touch" Scroll down to "Graphic Preferences" And click on it. Set Automatic to off. Change the Refresh rate to 90hz and then in rendering resolution, try it at max and see what the performance in your game is like. If it's bad, lower this setting until you have the best balance for performance and picture quality.
Are you talking about the Pixel override in the Debug tool? Or the Rendering resolution in the Oculus app?
Is your GPU a 1070?
If you are running the latest v25 build, there seems to be quite a few stuttering issues reported. Mine was running great on v23 but now on v25, there is bad random stuttering on link and the tested link cable speed has dropped. Also, 500 bitrate is too high, 250-300 is plenty and any higher can cause stuttering/audio glitches
I have a 3070, I'm using Oculus Debug Tool to set the SS. I'm on version 25 of Oculus software.
Any idea how to fix it? 250-300 is quite a noticible downgrade tbh.
I think you just need to accept that VR is very demanding. With a 3070 I imagine you should be aiming for 1.4 and 250. 500 is going to put a fairly hefty overhead on your CPU, and 1.5 is too much strain for your graphics card. I run 1.3 in Occulus software and 250 bit rate in debug tool on my lowly 2070S, everything else on default.
Wow - that's a very high FPS you are managing. I just hit 90fps with my 2070S with settings on kinda low to medium, maybe 5 cars on the track. I still feel that bit rate is your issue though, that is less about GPU and more about CPU. Have you tried lowering it to see what it does to performance?FPS is not the issue here mate, with AC I'm getting 90fps + 50fps headroom stable (140fps average). The issue is the occasional stutter / audio stutter every now and again. This is not related to FPS.
Looks like many others are having this exact same issue on V25.
What rendering resolution are you using? In the Oculus app.
