I'm not sure if this will be of any help, as I tweaked the memory using DRAM Calculator probably 18months ago and just carried the settings over as I've changed cpu twice and mobo once.
I started with a msi x470 with a 2700x cpu, then moved to a 3800x, then a x570 mobo (current one in sig) then upgraded to my 5800x cpu.
This is my memory:
https://www.overclockers.co.uk/team...3200mhz-dual-channel-kit-black-my-08l-tg.html
This is the Calculator settings from 2019 that I use. No idea if its still what is
recommended.
Sorry but I'm not going to faff about resetting all the timings to do a comparison.
But I do have all the images I took of the bios changes I made on the msi x470 gaming pro carbon, and my current setup (which is running the same timings).
If its any help, they are here:
https://photos.app.goo.gl/SMH93EQmbdig6AwE6
Have fun
