In my original post I linked another audio forum thread where the discussion was on running double cables. I'll just copy and paste some text from that thread:
Every one of these quotes is from a separate person.
I started with a single run of the RSA P!!!'s and then added a second set ... the difference wasn't night and day ... more like dusk to dawn ... but all positive with no down side
the overall presentation was more relaxed and natural sounding with more swing and sway (PRAT)
I could tell immediately that there was an improvement, but was hard put to put my finger on what improved
Doubling up on the wire from amp to speaker made a huge improvement on my system. Perhaps, because the speakers are 4 ohm, but it sounded dramatically better. I was quite certain I wouldn't hear anything, but it was the opposite. TRY IT.
Amazing.
I use a double run of Morrow Audio newer SP3's and wont go back to regular bi-wire method in a single cable!
However, I also do advocate trying double/parallel speaker cables for speakers having only one set of posts. Going with heavier AWG has almost always resulted in a preferred sound quality.
Then I recalled that I could double the speaker cables, and doing so brought more definition as well as more relaxed treble
from
https://www.dagogo.com/daedalus-aud...er-and-bass-optimization-woofer-bow-review/3/
And here is an explanation again from the audioon.com link why using double speaker cables would benefit.
I note that he states in the review that his "guess is that the primary benefit is in the increased total gauge, a variable I believe is primary to the attainment of superior sound. Very simply put, the more metal, the more musical nuance and grace." The halving of resistance that will result from using two identical cables in parallel, relative to the resistance of each cable, could also be accomplished by using a single cable three gauge sizes larger. However the doubled pair of cables will also reduce inductance by a factor of two, while using a single cable that is three gauge sizes larger and is otherwise similar in design will not come close to doing that.
