That's what I thought, but shouldn't at least 1 core be running at close to 100% in that circumstance?
Depending on the monitoring software that you're using it may be hard to spot, especially if you have transient peaks. Give it some 3D mark or heaven, something that mostly hits the gpu. If that gets you into the high 90s then your bottleneck is elsewhere. Could be cpu, could be ram speed, there will always be a bottleneck somewhre depending on what you're doing. Maybe get into a newer platform when you put the order in for the airflow case that you need.
