- 17 Jun 2012
- South Wales
Looks really promising .... But god it is begging for VR
Can we just let them actually finish what they started for trying too add even more new features.
Whatever you do is make sure its installed on an SSD, the GPU, CPU... they don't really matter too much, as long as they are not complete potatoes, Ryzen 2600 / 8600K + GTX 1060 6GB / RX 480 8GB for 1080P is perfectly ok. but if its installed on a spinny drive it will run like a bathtub full of rusty nails.I will have another go when it's free to play again.
There was to many bugs last time.
I got way better than that, and I play in UHD.
So bring it on![]()
Current cloud tech is still in active development and not yet final. There's ongoing work on SDF occlusion which should help alleviate the graphical artifacting (visual dots in the clouds). Additionally, we are working towards having local VFX for the clouds (similar to the gas clouds around rest stops) which will make a big difference in overall quality.
Known Issues
- Gas Clouds on Crusader appear to have moving graphical artifacts that appear as dots. Current clouds are still in development and not final. See note at the top of patch notes.
As early backer of $40 I log in once or twice a year to see if there has been any progress, generally the answer is no and I regret wasting my bandwidth on the download and immediately uninstall.
Last time I logged in was Oct / Nov 2020 (I think!) and there was still nothing to actually do. Has much changed or should I not bother?
I actually backed this for SQ42 not SC but reading some of the above it looks like Bethesda will have Fallout 6 out before SQ42...
Nice. I have watched the first 10mins of it. So far its really good!This is really good.
You can solo many missions in the PU now.There is nothing here for single player content players. Check back in 2030 for version 87.43.2221
What exactly have you done already in the game to warrant saying that there was nothing to do back in nov last year?As early backer of $40 I log in once or twice a year to see if there has been any progress, generally the answer is no and I regret wasting my bandwidth on the download and immediately uninstall.
There is also the below:Nope still not that much, you have bounty missions and mining is pretty fleshed out now, spend two weeks in it at the moment and you'll do everything you can do at least 10x times.. desperately needs a new system. Looks good though and it is a lot more smooth than this time last year.
The roadmaps mean nothing and can be changed on a whim. Haven’t you learned this yet?There is also the below:
I may have missed some stuff there but that is a lot of stuff you can do in the game atm that will keep you occupied for a bit.
- Delivery Boxed missions(either one box from Point A to B or collect boxes from A B C and deliver to D or Delivery volatile cargo where you either have x amount of time to deliver else the box explodes or you cant use Quantum travel to travel and deliver the boxes.
- FPS bunker and Cave missions
- Various Pirate missions where you interact with some NPC's directly.
- Investigation and search missions(Search for cargo or a person in a derelict crashed ship on planet surface or in deep space)
- Comms array missions where you scan and deactiate drones that are blocking a comms array satalite.
- 890 jump mission
- Bounty missions all have rep system( you go from killing basic bucaneer fighters all the way to finally going toe to toe with a idriss)
Obviously if you have done the above a lot and is burned out, thats fine and its no different to getting burned out on any other game(for example i and many are burned out on valheim).
3.14 will have two things you can do.
- Nine tails lockdown dynamic event
- Xenothreat remastered dynamic event
Anyways a **** ton of stuff just been added to the roadmap!!
TDLR, its all related to Server meshing and AI!!!
https://robertsspaceindustries.com/comm-link/spectrum-dispatch/18227-Roadmap-Roundup-July-14th-2021
Don't get me wrong I'm not slagging the game off at all but there's still a long way to go. As you said I've been playing it solid for what 3-4 months so yeah burnt out from it hence the dream of another system somewhere different to go and explore.There is also the below:
- 890 jump mission
