Leaks - Nashira Summit aka Navi 31:
AMD Nashira Summit GPU spotted in AotS database - VideoCardz.com
its just another gpu we cant buy![]()
I didn't think DP 2.0 was that close.
Imagine the heat and power consumption tho to match...RDNA 3 could make AMD’s Radeon RX 6900 XT successor 250% more powerful
AMD's Next-gen Radeon GPU Could Be 2.5x More Powerful | Digital Trends
More powerful definitely not, as powerful maybe... in certain workloads such as ray-tracing or mining...
I don't think either AMD nor nV could keep heat under control with that kind of perf upgrade.
"This space heater also plays games!"
AMD said RDNA 3 would be 50% performance per watt improvement over RDNA 2.
The 6900XT is 300 Watts so 2X 6900XT would be 600 Watt, or 450 Watt with the +50% PPW, and 550 Watt at 2.5X 6900XT
The RTX 3090 is 370 Watt.
The R9 290X2 was 580 Watt, so its not as if AMD haven't done 500 to 600 Watt GPU's before and when you're getting MASSIVE performance who really cares and i don't think anyone would argue two and a half times as fast as a 6900XT or RTX 3090 isn't MASSIVE performance.
Edit, that is a 'real' 8K GPU and then some...
My 200W 3060Ti already puts out more heat than I was bargaining for. Had to limit the frame rate in BL3 otherwise the case was becoming hot to the touchWhat kind of people would actually buy a 500TDP graphics card
I suppose if you live in Iceland or the South Pole then it could be feasible. I certainly won't be going above 300TDP next generation. I want TDP to come down not up.
My 200W 3060Ti already puts out more heat than I was bargaining for. Had to limit the frame rate in BL3 otherwise the case was becoming hot to the touchAnd that's with what I consider "normal" cooling, 2x 140mm case fans, in push-pull. The air at the back of the case was hotter than I've ever seen from any of my previous rigs.
And that's a mere 200W GPU500W? Holy moly!
An RTX 3090 is already approaching 400 Watt.
