- 27 Mar 2013
I've also noticed the percentages don't add up. For example the first 5 add up to about35% then there's a few 0.1%ers but no where near the massive drain I'm seeing.
I've just tested it out and it works OK for me.What do people use as an alternative to smart view? It doesn't find my tv and when I looked it up people are saying its been broken since Android version 11, we're now on 12.
Are you using a Firewall on your phone? I had to configure mine differently to get it working. Initially it wouldn't work at all.
The Firewall would need to be downloaded as an App.Hmm firewall on my phone? Where do I look for that option?
On my old S4 phone it connected easily.. and the weird thing is I can cast youtube videos to the tv, just not the screen.
It doesn't sound you've got one installed. Sorry, I don't know what else to suggest.
So worth waiting for the s22 to see price drops on the s21? Been out the game a while.
Is anyone having any weird issues with the latest software Android 12?
Mine updated last week, and the pull down menu toggles seems to have an issue with the screen rotate icon needing more than one press.
Moving the icon to a different position doesn't change its behaviour, and all the other toggles work fine.
Can anyone share what the screen on time until full battery drain is like on their device now after a year? Really interested if it's still on par with day one or has drastically reduced over time.
S22 looking good for me. Squared off shape with S pen. Looks pricey though?
Trying to find out if its dual sim and micro sd? My S10+ can't do all three which is a pain.I guess it'll be a curved screen and ultrasonic fingerprint? I'm fed up of TPU screen protectors on my S21U, not buying the S22U if it's the same.
5:35hrs and 44% left5 hour hours ish for me.
