EZDIY-FAB USB 3.0 (3.1 Gen 2) Internal (19-Pin) Header to USB 3.1/3.2 Type-C
Well its better than nothing, as long as it stays within the spec of the 19 pin
would not want flames
- / NOTE: Does not convert from 5GB/s to 10GB/s
- Easy way to access USB-C and support front panel header, doesn't require to have latest motherboard to experience USB-C technology.
That is incorrect, you cant experience USB-C technology 10GB at 5GB 19 Pin USB speed.
Well better than nothing, you get to use Type C Devices at half transfer rate & hope
it don't make smoke, The circuit board must have a safety cut out of 5w,
For the price & always send it back after trying it out .
1 Star ratings not showing , wonder what they said
Let us know how you get on with it
