- 18 May 2010
- London
When was that released, I only updated my chipset this morning and it wasn't this, or was it?
Afternoon.
Is that really what it does, or just a guess?https://www.amd.com/en/support/kb/release-notes/rn-ryzen-chipset-4-03-03-431
"Updated processor power management settings for performance and power improvement" aka "we lowered boost clocks"?
Use DDU is a program to deep clean the gpu driverI'm also getting the missing files warning when installing... but I also can't uninstall due to... missing files!
Any ideas for a work-around?
Reinstall the previous version, then uninstall them and should work. Good practice to delete the c:\AMD folder after you've uninstalled too. What I had to do.
Had issues getting these installed where it was coming up about missing files / directories, usually I install over the top but this time I had to uninstall the previous version of chipset drivers, delete the c:\AMD folder then they installed fine.
Not seen you around in a while.Installed for me with no issues.
Release Highlights
- New program support added.
- Six new drivers added.
- Fixed pop-up message "AMD Chipset Software is not responding" when the installer is launched and UI screen is clicked.
Known Issues
- Sometimes custom install fails to upgrade to latest drivers.
- Text alignment issues may be seen on Russian language.
- Manual system restart required on Non-English OS after the installation is complete.
- Windows® Installer pop-up message may appear during the installation.
- Uninstall summary log may incorrectly show uninstall status as fail on non-English OS.
