https://www.dell.com/en-uk/shop/ali...3dw/apd/210-bdsz/monitors-monitor-accessoriesSorry, where are you ordering these from?
Only got my order in at 10:25For context helps to know your order timestamps, because I would suspect older orders to be delivered sooner.
:O What time did you order? I got mine in at about 0900 and I've got 7th Apr![]()
I paid £847 with the 23% Advantage discount, I said that the code UKAW3423DW5 should have been on the order but wasn't showing for some reason. I'll be if I get the same £804 as everyone else![]()
I have the same monitor. Personally, I’m happy with it and will wait for this initial tech to mature a bit I think. It’s OLED, I’d be petrified of burn in. I’ll see how it goes.Got my order in for £804 (but also -£30 with AMEX and possible Quidco).
I currently have an LG 34GN850 (which I'm extremely happy with) so wondering if you guys think this is worth the upgrade? Not really sure how easy it'll be to sell on my current monitor.
I suspect they'll come back and sort it after you receive your order in that case, it seems that they can apply post receive discounts but not before you get it.
ye using 7 year old 4k 60hz graphic design acer atm. I think like this going down from 4k gaming to widescreen gaming ill save up on gpu upgrade since i dont have even freesync been playing some games around 40fps at 4k. Should be nice upgrade only worried about being widescreen not gamed on anything like that.Welcome. So you finally decided to pop out of your secret base I see?![]()
The lucky ones that got your orders in, how long before some of your 38" appear in MM![]()
Sorry, what is MM?The lucky ones that got your orders in, how long before some of your 38" appear in MM![]()
The forum members market. You need a certain amount of posts to see/use it.Sorry, what is MM?
Ah figured as much, can't see as always been a lurker and joined for this thread. Will have my 38" to go to a new home if the QD-OLED is as good as it sounds.The forum members market. You need a certain amount of posts to see/use it.
I apologize for the delay caused, I see that there is a material shortage which is being fulfilled. Once it is fulfilled it will be shipped at the earliest possible
I apologize, once the order is placed we cannot make any changes to it, if needed you can return that order and place a new order, with the discounts applied.
