Didn't you just order a QD-OLED for the pc gamingI think i'll be mad if i buy this.
I have a 65" GX OLED in my living room, 55" GX OLED in my bedroom, 65" QN94A in my cabin.
4 expensive TVs.. but but this is for pc gaming...!
42" is shipping if you got order in towards start, likely now a backlog. Mine is due in an hour
Yes it will have ABL and no you cannot turn it off (unless something significant has changed which I doubt). I will hopefully be able to comment later on text as planning to also using mine for work and play. As for burn in being an issue. There are mitigations in place and newer panels have become more resistant, but no absolutes and may be a chance of you have same static content up 12 hours a day 365 days a year etc. Is prudent to have screen turn off if not in use after short while, black background, hide taskbars etc.
Which HDMI 2.1 cables do you all use btw? I'll need to order it too.
I'm from the Netherlands so can't order any from the UK. All I need are model names.I've used a few certified 8k one's in the past (for my 65"OLDB9 in the living room), had no issues with my XBOX-X so I'd just go for some cheap ones (~£10 for 3 metres), can't post a link as Overclockers sell HDMI cables...
Aren't cheap HDMI 2.1 cables crappy? Giving issues like flickering or bad pictures? What about Hama?
Yes... hahaha but its delayed so thought of getting the oled42 instead.
But 42" sharper and higher ppi...!!! We have waited like +8 months for the 42" to arrive so a week or two is nothing.I'm in the same position, although I'm even less patient and ordered a 48C1 yesterday! Might switch to this...
Probably not regarding any killer differences. I would have gone for the 48C1 too as 48" is really the max but it would be a bit inconvencience after some time.Just had a look at my PC on a 65"OLEDB9, and to be honest I'm happy with the text clarity on that (from a useable distance), so I think (for me) 48" will be fine...Given the 48C1 was under a 1k with the John Lewis protection plus (5years), I can't think of a compelling reason to get the 42C2 at £1300 without protection plus, another £140 with it, I know it's a year newer, but other than a preferable size, is there any killer differences I'm missing?
My 48" has arrived, if only I had time to set it up and play.
Native ultrawide support is the standout for me. Other than that I'm happy with my CX.other than a preferable size, is there any killer differences I'm missing?
How exciting!
C1 or C2? Regardless, let me (and all) know your thoughts please...and picture if possible...
Just got an email that my JL order from early Feb is “Delayed”..
Hoping it’s just a small initial stock delay and I haven’t been chucked down the backorder line.
Anyone else order with JL and heard anything?
