Google soundbar reviews it will tell you the best options at the various pricepoints.Within reason (price wise) is adding a sound bar a good idea? If so what does everyone favour
You can darken logos and set a screensaver for a short period of inactivity, but screen burn should not be a concern on modern OLED TV's.Is there any extra preventative measures I should take regarding screen burn on my 65" C1?
Is there anything else I should sort on the set up? Pretty much running it all stock and returning the audio EARC direct to my amp.
Anyone tempted by the OLED 42C2 coming out soon as a monitor?
It's pricy at £1,300 but I held off getting a 48CX as it was just too big for my desktop in terms of lack of pixel density at that distance.
Link borked, presumably because you don't use 20 posts per page
Link works fine.Link borked, presumably because you don't use 20 posts per page![]()
Better!I'm in pro mode... https://forums.overclockers.co.uk/posts/35519231/
Link works fine but goes to the wrong post, instead landing on a completely irrelevant one from several years before the CX came out. I beg your forgiveness.Link works fine.
yupp, link was borked
what's your thoughts on the C1 in that room during the day? still have a Panasonic plasma sitting 90deg to a south facing window...it's almost like one of those 'what do you see' pictures, ie if you focus on the reflections that's all you'll see but still watchable if you can can (try to) ignore the reflections....
pets and oled no thanks not for me, but your Livingroom is nice tooIs there any extra preventative measures I should take regarding screen burn on my 65" C1?
Follow a few recommended settings, there are quite a few things to change. Don't use vivid, for example.
Also
Get curtains, and block out skylight
Use rugs
Get more soft furniture to break up "bathroom clappy sound"
Get a second sub
Raise Center, remove from inside stand.
I don't need (or want) curtains, it's North facing bifolds (so no direct light in) and I tend to watch TV in the evenings.
I appreciate acoustically that might not be ideal but this room is open plan and also connected to another office/kitchen, it's never going to be a "cinema" space.
One sub is plenty for me. Got a bk xls400![]()
That's "only" a sealed, 12" 400w amp sub. It's a good sub, it has limitations though. For movies ,.big room and open plan you probably need something meatier.
With reflective surfaces it'll sound like a bathroom, clap your hands is there echo?
Nah its not bad for echo. I'm not going to do the "treatment" of the room like foam pads on the wall etc. I just wanted a decent TV set up that isn't too much visual impact on a family room.
Im sure it's not the most optimal audio set up but a nice room to be in (old pics /before cleaned etc!)
Every house is a compromise, just live with it. Also I've noticed hornet stinger does tend to recommend very expensive subsNah its not bad for echo. I'm not going to do the "treatment" of the room like foam pads on the wall etc. I just wanted a decent TV set up that isn't too much visual impact on a family room.
