Iirc, the benchmark hit single digits for me, can't recall if it was before the patch or/and after the patch (which fixed the textures issues). I found it a poor representation of gameplay perf., iirc, guru3d or/and hardware unboxed also stated the same about the benchmark, probably why quite a few reviewers used their own sequence of gameplay than relying on the benchmark.
45-50 fps at that res. sounds about right, iirc, that is about what the 6800xt would get too. Frame latency is the real key though as if it feels stuttery i.e. latency isn't a straight line and looks rather bumpy (consistently) then that indicates a shortage of vram.
Managed to get deathloop recorded, just reinstalled, which seemed to fix the issue.
Also got resident evil village and recorded some gameplay, another game that "apparently" is awful with anything less than 16GB vram.....
 On a separate note, RE village looks FAR better than when I played the demo/beta ages back.
Uploading now so hopefully 4k processing be done by tomorrow morning. Seems that if you enable FSR or DLSS, you need to restart the game otherwise you get some spikes, saying that it did say the game might need to be restarted after applying FSR as you'll see in my video.
			In your head (a special place
) maybe. Rest of the sensible people understood that at the price point the 3080 FE was it was a bargain and it took two years for a handful of titles (if that) to show up where you run out of vram in certain scenarios. People reading your posts would think the said games won’t even boot up unless you have 24GB epeen vram available
One could say the conclusion was that the 3080 and performance before it does vram
This guy gets it
Titles recently where I am wanting far more FPS especially since I have a 3440x1440 144/175HZ display that I want to get the most from:
- deathloop, even with dlss - fps is around 90-100 in outdoor areas
- cp 2077 - maxed and with
dlss perf., getting about 60 fps outdoor areas with dips below that
- dl 2 - maxed with dlss balanced, about 70-80 fps outdoor areas
Of course, I could be sensible and drop some settings a notch or 2 to bring fps closer to 144/175 but some of the most demanding settings i.e. mostly RT ones make a big difference in visuals such as psycho RT lighting so I'm not willing to budge on them.
Funnily for 4k, it's actually ok/better because my oled 4k tv is only 60 hz so 3080 can hit that easily enough with dlss, especially since balanced and perf. are more usable when sat 6/7 feet from 55"
Just read a rumour that next gen nvidia gpus might come with 24GB vram, hope so as then 16GB won't be enough
