*** Forum Update - Official Issues Thread - Please check the OP for known issues ***
Caporegime
5 Sep 2010
So if I just post the url of a news site it'll change it to the preview image?
I'll test it;
https://www.bbc.co.uk/sport/football/61490237
It doesn't work for me. I've been using the insert link option. Is there another option I should be using?
Copying and pasting the link into your reply works.
Sgarrista
Commissario
9 Aug 2013
Bromsgrove
The default selection isn't good enough, hence asking for the bright colours to be reinstated?
Can look into it if you insist, but I dont think the "bright" colors are particularly easy on the eyes across all the themes where the default options work on all of them.
Red Default
Red Bright
Green Default
Green Bright
Yellow Default
Yellow Bright
Don
OP
19 May 2012
Spalding, Lincolnshire
Red Default
Red Bright
Green Default
Green Bright
Yellow Default
Yellow Bright
The bright colours stand out more specifically when a Moderator posts a warning or comment within a thread - for the use they normally get, then easy on the eye isn't a requirement (although I get your point that the default colours are much better for normal users colouring things)
27 Feb 2015
I m starting to wonder if some of these problems with embedded posts and the like might be changes in browsers themselves and timing might have some coincidence.
Another forum is having the problem in firefox now but they didnt do an update, and I was browsing a website on my android phone and the page takes time to settle down with its loading, its ultimately a problem related to lazy-loading which is now rampant across modern web sites.
