Its also a well known fact that vegetarian agriculture like rice is one of the leading causes of greenhouse gases and the methane is more than 30 times as potent as carbon dioxide. If you scale up the size of the Vegetarian agriculture to replace the animal agriculture then the total amount of greenhouse gas can get worse and the type of greenhouse gas produced is worse.The myth? lol So you disagree with the science then? Its a well known fact that animal agriculture is one of the leading causes of greenhouse gases.
Instead of looking at the total size of the animal agriculture against the size of the vegetarian agriculture. Look up say how much greenhouse gases is produced to feed say 10million people via animal agriculture v 10million via vegetarian agriculture. Once you scale up the vegetarian agriculture to feed mass amount of people you get runaway major greenhouse gas problems far worse then the current animal agriculture industry.
Rice farming up to twice as bad for climate change as previously thought, study reveals
Levels of overlooked greenhouse gas are up to 45 times higher in fields that are only flooded intermittently
