10GB vram enough for the 3080? Discuss..
Status
Not open for further replies.
Some people just want the best and have the money to buy these things. Everyone buys to their own preference and means, depending on their priorities.
Its what i have been trying to tell people, i don't need 90 vs 120 FPS, what i need is more VRam.
The GPU i have is mostly fine for my needs, apart from Volumetric Clouds in Star Citizen, which absolutely murder it, i just need a bigger buffer.
Why not just pick up a 3060 12gb then?
  • Haha
Reactions: TNA
Just turn down some settings, with your £700 GPU, what's the problem?
That's what I had to do from day one with my 3080. I know you were being sarcastic here, but a $700 card has to have the settings turned down sometimes.
-And here we are, back to my original point. Is turning down settings only a "problem" when it's because of vram?
  • Like
Reactions: TNA
Well it is when you have a narrative you wish to push :p:D
Then you get the “Oh no, but look at thread title, it is a about vram”. The funny part is, the same users then proceed to bang on about off topic rubbish when it suits them in the very same thread :cry:
I got the impression it was a sarcastic remark that a $700 graphics card shouldn't need to play at lowered settings. The problem is that lowered settings is a reality sometimes...even for a "$700" graphics card.
Now, if he wants to argue that turning down settings is fine when any other resource can't keep up, but unacceptable when it's because of vram, well, that's an opinion he's welcome to hold, but I don't find it persuasive myself.
  • Like
Reactions: TNA
To be fair my post was not targeting humbug specifically because this has come up here in the past before he got involved.
Unfortunately these days £650 is a mid range price point for Gpus but luckily the 3080 was on the 102 so offered near top tier performance.
How many would have rather the 3080 had 3070 performance with 16gb VRAM exempt maybe Humbug?
Bla bla bla.
Gave you a link that shows 33% performance improvement, which you did not refute. Now you are stuck strawmaning :cry:
Just using this quote to link into the discussion.
When you take into account the extra power draw of the Ampere 3070 over the Turing 2070 IMO the amount of performance per watt increase from Turing to Ampere isn't great, certainly less than AMD aimed for from RDNA1 to RDNA2 and what they claim is going to be more than 50% from RDNA2 to RDNA3. Putting extra memory on the 4080 is only going to add to the power usage, my 2060 12Gb uses a fair bit more power than the 2060 6GB.
At a cost i believe it is, the instant we accept a $700 GPU is a "compromised GPU" we are #######.
How many would have rather the 3080 had 12gb VRAM in the first place and this thread wouldn't have happened?:p
But the MSRP of the 12GB 3080 is $500 more, that's proof Nvidia are actually doing us a favour.
That's because Samsung 8nm isn't much better for effiency than TSMC 12.
Nvidia should do better this time around unless they go for crazy clocks and all out performance but if they do there will be options to underclock/undervolt to dramatically cut power draw and improve effiency.
  • Like
Reactions: TNA
Exactly. Plus at the end of the day the discussion was about whether there was a difference between a 2070S and a 3070.
Nope. Because then the price would not have been the same. Just like it ain’t even until today. I still would have saved the extra money. What difference would the extra 2gb have made anyway? Same people would still be saying yeah but it does not run FC6.
Status
