- 19 Oct 2002
- Shakespeare’s County
Oh yes
BMW * rated tyres are not marketing guff.Same as BMW Star Mark...it's all marketing guff.
My point is that the tyres are different, and therefore it's not marketing guff.On an M3 I'd probably agree - I'm not so sure it makes a huge amount of difference on my 5 series diesel noticeably
In addition, Michelin have since released PS5 (although I know the PS5 doesn't replace the 4S but rather the 4 at this stage) and other top end tyres have been released like Conti SportContact7 which could then outrival the older PS4S * Mark version. Plus there's additional cost for * Mark over standard. My 245/40/19 would be an additional £15 a corner!
Fair! I didn't realise they did make that much of a difference tbh.My point is that the tyres are different, and therefore it's not marketing guff.
I bought a set of Goodyear Vector 4 season G3 a couple of years ago based on this channels test. Worst tyres I have ever had in every way. Never bother with tyre reviews after that.ooo, all seasons tire testing is back !
Had some Gen 1 Vectors and they were awful.I bought a set of Goodyear Vector 4 season G3 a couple of years ago based on this channels test. Worst tyres I have ever had in every way. Never bother with tyre reviews after that.
Anyone have any experience of all season tyres, Michelin Crossclimate 2 Vs continental contacts?
I've had crossclimates on for 2 years and was considering trying the continentals out.
| Tyre | Total | Dry Braking | Dry Handling | Wet Braking | Wet Handling | Straight Aqua | Curved Aquaplaning | Snow Braking | Snow Traction | Snow Handling | Noise | Price | Rolling Resistance |
| Michelin CrossClimate 2 | 92.2% | 38.6M | 79.3s | 32.20M | 99s | 78.80Km/H | 6.5m/sec2 | 31.10M | 5.50s | 110s | 69.6dB | 93.99 | 7.9kg / t |
| Hankook Kinergy 4S2 | 91.5% | 39.20M | 79.3s | 31.60M | 97.1s | 80.50Km/H | 7.5m/sec2 | 32.30M | 6.00s | 114.3s | 69.4dB | 87.89 | 8.5kg / t |
| Goodyear Vector 4Seasons Gen 3 | 90.8% | 41.60M | 78.7s | 31.90M | 97.5s | 79.30Km/H | 7.3m/sec2 | 31.50M | 7.10s | 114.7s | 69.5dB | 95 | 8.2kg / t |
| Continental AllSeasonContact | 89.5% | 41.60M | 78.8s | 33.20M | 98.1s | 78.30Km/H | 6.7m/sec2 | 32.40M | 6.80s | 115.5s | 69.7dB | 91 | 8.1kg / t |
It’s a reasonably good review. You can’t tell the long term wear and abilities of the tyres from it. The wet handling/aqua of the CC2 is slightly worse than the other tyres, but then it starts off with less tread than any of its competitors.Results Grid Tyre Tests At Tyre Reviews - Tyre Reviews And Ratings
Results Grid A Roundup Of All The Important Tyre Tests From Across The Globe, Helping You Select The Best Tyre For Your Car, 4x4 Or Motorcyclewww.tyrereviews.com
Tyre Total Dry Braking Dry Handling Wet Braking Wet Handling Straight Aqua Curved Aquaplaning Snow Braking Snow Traction Snow Handling Noise Price Rolling Resistance Michelin CrossClimate 2 92.2% 38.6M 79.3s 32.20M 99s 78.80Km/H 6.5m/sec2 31.10M 5.50s 110s 69.6dB 93.99 7.9kg / t Hankook Kinergy 4S2 91.5% 39.20M 79.3s 31.60M 97.1s 80.50Km/H 7.5m/sec2 32.30M 6.00s 114.3s 69.4dB 87.89 8.5kg / t Goodyear Vector 4Seasons Gen 3 90.8% 41.60M 78.7s 31.90M 97.5s 79.30Km/H 7.3m/sec2 31.50M 7.10s 114.7s 69.5dB 95 8.2kg / t Continental AllSeasonContact 89.5% 41.60M 78.8s 33.20M 98.1s 78.30Km/H 6.7m/sec2 32.40M 6.80s 115.5s 69.7dB 91 8.1kg / t
You are right. Any tyre is fine so long as they fit and are the right size but somebody was saying the * BMW are no different tyres when in fact, there is a massive difference in themi guess that make sense when the car is new, but when its, say 5 years old, is OE still "better than aftermarket"?
If they ever build my BMW 1 series, it comes with some bridgestones S005s, which everyone says are rubbish. the only Star marked options are the "Pirelli P Zero" no idea if they are any good, or if the sidewalls are as soft as cheese like they were that list time i used pirelli. There looks like there might be a continental SP6 that is BMW, but for what car? What works well on a rear wheel drive car with 300hp, might not work so will on a front wheel drive car with 265bhp. If BMW say, anything with BMW is fine, even if its "designed" for a completely different platform, then the whole star marked argument largely goes out of the window, no?
Its not like you can take tyres back and swap them if you dont like them. your either stuck with them, or you bin £xxx x4 and start again.
