Caporegime
- 18 Oct 2002
Have you met the human race?Surely people can't be that dumb?
But you forget that it costs them more to replenish now (plus they might be running low on stock hence the increase).but surely this is stock they already had ...
The Asus GeForce RTX 3070 TUF OC V2 that I'd been keeping my eye on no longer has the discount and jumped up to £599.99 on OC. I'm wondering if I should have got it when it was on sale at around £550 or am I better to keep waiting? I only really want it for VR and wondering just how much better it will be for this at £550/£599 compared to my 1660 Super?
Looks like my bet to pay £800 for the 6950XT has already paid off. It's £50 more expensive today!
No chance, drop the bling and the tax. Do you not want to go used for better spec?
Voting with my wallet and staying far away.If your current GPU is playing everything in your library, then why bother in the first place? AMD isn't going to be any cheaper this generation either!
this is a great point tbh, the only reason i was looking for a new card is that mine has been abused for 6 years now and i expect it will fail at some point. I'd like to get a new one, preferably Zotac again, so I can have another 5 years of warranty ....If your current GPU is playing everything in your library, then why bother in the first place? AMD isn't going to be any cheaper this generation either!
Only way I upgrade is if the 3000 series second hand values go up an insane amount.
