This.The high end B550 boards were only £120-£130 so shall see how the B650 do in comparison tbh.
Think Anandtech and kit guru did that.Are there any reviews that focus on gaming power consumption? Thanks![]()
You set your fans to the maximum percent you feel comfortable with in terms of noise when the cpu hits 95c. With my t30 120 fans i would set them 60% @95c for exampleSerious question: if the things constantly Turbo until they hit 95 deg, how are we going to keep our fans and pumps silent-ish whilst still adapting to load?
I'm sure there's a solution, but not one which jumps out at me.
when are these cpu's going on sale was thinking today or did I mis something?
Really? I have them all off until stuff start hitting 60c,both for the cpu and the gpu.I just run my fans at the maximum speed I will tolerate 24/7
Users who don't do that, will have lots of fan ramping up and down all the time with ryzen 7000
Im pretty sure thay existed in x570 and all intel boards. Not exactly a target, but you could change the thermal throttling point.MSI x670 boards let you set your own temp target. Don't like your ryzen 7000 CPUs trying to boost to reach 95c? No problem, change it to 85c, 75c or even 65c in the MSI BIOS
MSI X670 & B650 Motherboards Get Latest BIOS With "Performance Switch" For AMD PBO, Manual Overclocking & PBO Thermal Limits
MSI has introduced AGESA 1.0.0.3 firmware for X670 & B650 motherboards which adds "Performance Switch" & Thermal Throttle limits in BIOS.wccftech.com
I suspect PWM ratios may be different for the new boards since 95c is now a 24/7 safe point [not to mention the CPU itself will adjust itself to stop it going over this]Users who don't do that, will have lots of fan ramping up and down all the time with ryzen 7000
, i get the pound is weak but still, i have a block to buy too, might have to hold off geting up and running for around a week or 2Ryzen 9 7950X Techspot review up now:
Link:
https://www.techspot.com/review/2535-amd-ryzen-7950x/
Newsflash, it runs hot.
