Should post the workloads the CPU excels at too mate, as no one is buying a 7950X for just gaming.Ryzen 9 7950X Techspot review up now:
Link:
https://www.techspot.com/review/2535-amd-ryzen-7950x/
Newsflash, it runs hot.
) will be getting them for other workloads in which they dominate everything else comfortably.
True. But gives an idea of where the 7700X will sit.Should post the workloads the CPU excels at too mate, as no one is buying a 7950X for just gaming.
Most people (apart from me) will be getting them for other workloads in which they dominate everything else comfortably.
Do you take Dogecoin?CPU's are uploading to the website now.
Got get your wallets out guys!![]()
We always pay more. Now we get hit even harder.£779 for the top chip (ouch) kitguru said it would be £739, so much for it costing less or same as last gen, i get the pound is weak but still, i have a block to buy too, might have to hold off geting up and running for around a week or 2
Yup not bad! I have a bias towards 8 core CPUs though...
That is true, saw that.Could be worse a competitor is £819 for 7950X and £639 on 7900X.![]()
The wasted keystrokes keep on coming, perhaps you should stick to Netmums.Nothing like the excitement or hype from the prior Ryzen generations, sadly
Only just matching 12900k in gaming, running very hot, very expensive motherboards, DDR5 required, all negatives. Intel's 13th gen is about to tear this a new one as well...
Zen4 3D should be much more exciting, hopefully everything has matured by then as well.
Gonna check later see if I can afford a 7000 build. 7950 as will want the extra cores for blenderCould be worse a competitor is £819 for 7950X and £639 on 7900X.![]()
More cores = Brum!So in your eyes a 1700 is better than the 5600x and 7600x?
