@Gibbo said the 7950X was the best seller on OcuK so perhaps not that surprising.Yeah its was already there last night, hours after it went on sale BOOM! straight in at No1, like you said.
The rest of the Ryzen line is still dominating too...
its marginal gain between Zen4 and 12th Gen as far as gaming FPS is concerned.
13th gen intel will have a line up with the i5 beating the 7950x in games - marginally.
then AMD will bring out Zen4 3DX and take the crown again marginally.
It is getting marginally indifferent now!
still close7950X straight in at No1.
EDIT - Sorry Dons, I had a blonde moment and posted a competitior link it's been removed.
Can you edit your post please to remove the link from my post?Compare that to the 12900K which took weeks to appear in the top 12, never made it anywhere near No 1, didn't stay long before it dropped out again and has been occasionally popping in and out the back end of the top 12.
your mum and dads buying PC for their kids are not going to know about this. the kids might not know about this. AMD should just put this into their boost algo and default to some more reasonable power use or use the windows power plan to say "high performance" (highest TDP) "performance" (undervolting as this guy is doing) "efficient or energy saving" (like cap at 65w or 50w etc).
Less impressive than the PBO2 way. This is definitely losing some of the Zen4 goodness that comes from super high low thread boost. Could be up to 20% in some7950X at 55C
pretty much what the guy said at the end.
I know I've pulled the trigger on the 13900k but I'll be honest the more I've been thinking about it the more I think I should prob canx the 13900k and go AMD and grab a 7950x now and drop in a 3D chip when it comes out. Looking at the bench marks today across the board, especially in games like Tarkov and Star Citizen the 3D chips absolutely destroy it seems. Spend out a bit extra on the top mobo now and that should see me through to zen 5 3d and whatever Nvidia bring out in a few years. Also, save a few £ on the energy bill to going AMD with the undervolting.Lets not get ahead of ourselves.
However, the 7700X in that is 19.1% faster than the 5950X, 13% faster than the 12900K, its going to be tight, but when AMD launches Zen 4X3D its going to be a bloodbath...
or you can use the command keys to change profile with. so when you are in a demanding zone, get that CPU cranked up!You know what else is a good idea?
If they had a light wight app that loaded with Windows that has a few basic system readouts like a lot of apps these days have but primarily a series of buttons for different power modes, like for example:
ECO mode 65 Watt
ECO mode 125 Watt
ECO mode 170 watt
High performance Mode
Personal Profile 1, 2 and 3...
It just sits in your system tray so you can open it up, click a button to select from one on the options, sometimes people might like to render a video but on that day they don't want the CPU doing it running at 240 watts, save some electricity and do it under the 125 watt profile, with the way that energy costs are going, and the increasing environmental consciousness among people, it might be appreciated.
Guys, another quick question. AIO's and coolers, will they be able to fit AM5? Just occurred to me that you might need a mounting kit for AM5, same way you did for AM4
The motherboard backplate is fixed to the socket mounting frame, so technically you can can't remove it, some coolers, especially AIO's require you use their own backplate, that's a problem to look out for, but other than that the mounting for AM5 is exactly the same as it is for AM4, so provided you don't need to change the motherboard backplate it will fit the same as if it was an AM4 board.
AM5 is LGA socket right ie no pins
Scales pretty well at lower voltages then.
