NVIDIA 4000 Series
6 Feb 2019
So nearly every partner card has three fans on the front, none on the back.
The FE is quite a unique design. Is it better or worse? Cost saving or actually really good? I'm wondering if it would be nosier because of its design or quieter.
Anyone got any insight?
I've seen one AIB 4090 that has a fan on the back
Caporegime
23 Apr 2014
Bell End, near Lickey End
It depends on your case and airflow setup. I can imagine the FE would work really well in a fractal torrent for example.
1 Sep 2003
Redcar
I've got a 5000D 3 front intake, 3 side intake, 1 back exhaust, 2 top, exhaust.
I'm not worried about length of these cards, but I am worried about width and the 5000D is a pretty big case!
22 Jan 2007
It would seem they have already forgotten about that switch, then, as there's no reason to lock them down like that anymore. Well, we'll find out tomorrow, I suppose.
I called them about it and apparently they have no control over it. Completely down to Nvidia to sort out there end. So will probably be a cluster what not.
24 Sep 2020
Scalpers will scalp anything if they can make £500.
If these sell out, which certainly FE will - Then they will be on eBay for over £2k
People were stupid enough to pay over £2k for the 3090.
Coming back to my original point. You can't do that unless you're sure it's going to go out of stock. All models, everywhere. And the 4090 won't IMO. And I think scalpers know that – they're not that stupid. This is a completely different situation to the 3000-series launch. In every way.
20 Aug 2004
Yeah the motherboard to side panel distance is really going to be tested with these new cards. Good excuse for case makers to make new versions of small cases that tick the box of fitting a wide-boy.
9 Jan 2010
True but within a few hrs we shall see 4090's on ebay over 2k as only One card per customer on all AIB and Founders again ...
