NVIDIA 4000 Series
Apparently **** lock these to 1 per account and that even includes if you bought the 3000 series FE from them. Anyone know if there is any truth to this?
Can’t be right. There’s no way they would lock you out of buying a 4090 if you bought a 3000 FE.
Yep if you have a 3060 or above from them you can’t purchase this gen for two months. They posted about a hour ago.
I find this really hard to believe, it's illogical for them to do this.
Indeed!
That's crazy, seriously? Not that I was going to buy one anyway, even though it is an amazing card it's just far too expensive to play console ports with somewhat better graphics.
No chance, show me where it says this? :p
They’re the only supplier in the UK offering the FE4090.
You can’t purchase a 3000 series card but you can a 4000 series.
  • Like
Reactions: LiE
So anyone using any 3rd party applications to help or just f5 a few mins before 2? Last time I can’t remember the name of it but I had some chrome plug-in that pinged if a page changed.
I have the Alienware 3440x1440 OLED Ultrawide.
I’m thinking the 4090 will basically top the monitor out at 175fps in most games?
I’ll then go for a 32” 4K OLED monitor if/when they become available.
its overkill. you simply put are wasting money and better off saving the money for either a better display (which is already pretty good) or better audio.
Its crazy how people will jump on an expensive new toy which they cant even utilise to anywhere near its true potential for a pretty much non tangible gain in performance. the marketting machine is crazy.
