Don
- 20 Oct 2002
- Oxfordshire / Bucks
Everybody's head is different, so I hope mines good for me
The dust is tiny and at the bottom, so I can live with that. Others are probably the same or worse.
I'm not blown away with it yet. Just going to buy virtual desktop
Niggles
Still feels front heavy
No way can you play fitness games like Pico say, the headset will bounce and wobble around
Colour pass-through needs to be 3D. Everything looks weird, like my bed is on the floor
Light bleed causing lots of reflections
Face cover is a bit crap
after software update, the middle of the screen is blurry
Top strap is adjusted at the back, would be much better being back at the front, you need to lift the front not the back
Fans are going to dry your eyes out, I can feel the air hitting them quite a bit
anyway, let's get some games on
What software are you using with the Pico (apart from VD)?
I've just been to the Neo website, and couldn't see anything obvious.
Does anyone know what the difference is between medium, high and ultra settings in virtual desktop? I thought it might be the resolution, but that's set in steamvr as 100% ??
:edit: OK, I think it is the resolution it sends to steamvr. Assume ultra is native panel res? I've been on medium and thought that looked awesome![]()
You're Alive!Hey TheOracle. I see you got the Pico 4 and no dead pixels. Must be your lucky day, or that eye surgery worked
Your edit is correct, it's just the resolution that Virtual desktop sends to SteamVR. I am not sure what the Ultra resolution Virtual desktop uses for the Pico 4 but it didn't use native resolution for the Quest 2 or Pico neo 3. Ultra resolution is 2688x2784 in Virtual desktop for those two headsets.
'that thing'.... you mean ByteDance or Zuckerborg?Will this be the new Oculus be for that thing bought them out?.
No way will the battery last 2 hours
but I have seen some trapped dust![]()
was your headset box "Sealed", mine is, i hope there isn't dust in there
