- 22 Mar 2017
- Poland
fineNo, and I've had to bend the cable pretty aggressively to get the side panel on...![]()
I'm not discrediting anything that's been reported but the supplied cable isn't very very bad/dangerous.
Hell yes!4090 owners are you pleased with your new cards .
Hello. I will be buying Gigabyte Rtx 4090 Gaming OC. But is this worth and safe? I will be using adapter from card to plug.
My psu is Seasonic 1300W Prime Platinum.
Here read pls:
The horror has a face - NVIDIA’s hot 12VHPWR adapter for the GeForce RTX 4090 with a built-in breaking point | igor´sLAB
Those who are now beating up on the new 12VHPWR (although I don’t really like the part either) may generate nice traffic with it, but they simply haven’t recognized the actual problem with the…www.igorslab.de
Do i will be have issues? or not?
i would disagree because even cablemod cables disclaim a 35mm bend clearance, it isnt robust enough to be a consumer standard, they have got to increase the pin area to make it more robust
- The problem is not the 12VHPWR connection as such, nor the repeated plugging or unplugging.
WHAT cable i must replace?The adapters are all NVIDIA, I believe, so the answers is no, you need to replace the cable.
That or do a better job on the solder joint so it holds better if bent at that point. Cos from what i've read, bending is whats causing the poor soldering joints to break putting more load on certain wires than others causing more heat therefore melting.i would disagree because even cablemod cables disclaim a 35mm bend clearance, it isnt robust enough to be a consumer standard, they have got to increase the pin area to make it more robust
Literally read this thread, cablemod.WHAT cable i must replace?
ok where i can get cablemod?Literally read this thread, cablemod.
I can afford one and I’m choosing not to (stock or no stock)Whacha wanna bet it the guys who can't afford one who are being the loudest over this?
Oh noes - a couple of people didn't connect an electrical connector properly & it caused some melty melty ness... guess what... PCI-E 8 pin connectors have done the same when you don't plug them in correctly.
I dont think they could, a larger connector with more pinouts would mean a change in the design of the heatsink to compensate and maybe even the pcb itself if its surrounded by components. Won't happen.I think they do as well, especially for the 4090ti. But will they? I can imagine they roll out a new cable for existing purchases, but could they really introduce a new socket in time?
I give up.... somebody shoot me please.ok where i can get cablemod?
Any reputable hardware store.ok where i can get cablemod?
Oki thankkkkkkkkkkkkks youAny reputable hardware store.
I just cant get my head around how someone will spend £1700 on a GPU then complain about a £35 cable , on a gpu costing significantly less then would agree some may complain about the extra outlay but if your happy to spend £1700+ an extra cable isnt going to break the bankno i was just commenting that your original comment doesnt apply to the universe of enthusiasts.. there are enthusiasts who would still maximize value for money
also i meant the card has a lifespan of 2 years because i would be upgrading to 5090s in 2024 without fail
thats also the reason i dont bother with EK blocks and similar stuff
regarding the connector it has an even shorter lifespan because they may rework the pin dimensions under atx 3.1
