dood it's the tiktok area you can't take anything at face value anymore, people will do anything for some attention, reddit is no exception
also if you look at that thread you'll see I've always posted the most up to date theories surrounding the connector.....
forums.overclockers.co.uk
just because I have an open mind = I'm a retard okay dood.... keep telling me I have buyers remorse like I desperately need that 2k...
only if you buy AMD it seems and you din't wanna play a game with max settings anyway, and any minor issue with the competition is a full blown product recallSeems to be, i forgot when you buy a new gpu you're also buying into a religion. Or some do at least.
Check Your 4090's 12vhpwr Connectors To Make Sure They are in Pristine Condition
Are the actual pins on the connectors smaller than the regular 6/8 pin pcie? The old 6/8 pin connectors are Molex Mini-Fit Jr, with a 4.2mm pitch. The new 12VHPWR connector is Micro-Fit, with a 3mm pitch.
