Thanks.As long as bit locker is not enabled it’s safe to press Y to reset the ftpm. Bit locker is just hard drive encryption, if it was turned on which it’s not by default then windows wouldn’t start if the keys were reset.
Had to reset mine when I installed the new CPU.
She's very toasty under Cinebench r23. Hits 90 degrees, which I belive is thermal throttle!
I've seen bits and bobs about putting a -30 on the cpu in bios. What exactly is this? Is this what everyone is doing?
EDIT: 85 degrees just loading up Warzone!
240 AIO with good application of Grizzly.
thats an astonishing difference guys.
Now just to really make sure it's stable and work out how to get it to auto load in Windows 10.
EDIT: Think I've set that schedule propoerly, seems to be working. I thought it would physically load the program but I dont see it. Does seem to be working though when I stress it.
Yup, all there. Fantastic.If you open PBO Tuner manually it will have the settings showing in it. Worth doing just to make sure the scheduled task is applying.
What resolution are you playing on beany_bot. Interested to see how it fairs in Warzone. Full setup would be helpful too.Yup, all there. Fantastic.
BIOS would be better but its a great workaround.
Gulp!
Not looking forward to fitting mine tomorrow with my air-cooler!![]()
1440p. its much better now with the PBO thing. full setup in my sig.What resolution are you playing on beany_bot. Interested to see how it fairs in Warzone. Full setup would be helpful too.
Ah, forgot I can't see the sigs on mobile.1440p. its much better now with the PBO thing. full setup in my sig.
Well well, that's good to know! Cheers!You can in landscape![]()
