I've had the Trinity since launch and it's been fine (and quiet).
Same here. I see the block has been showing in stock on the EK site. Kinda hoping that means OCUK are due stock.Still waiting on a waterblock for the 4090 FE
Spoke to OcUK and they're unsure on delivery dates, so pulled the plug and went to EK directly. It's been sat in my office for 2 weeks, crying in the corner.
Can I ask, do your fans sound like this when they start spinning up?Zotaks almost always run about 30-40% fan so pretty much cant hear it either way!
Definitely worth putting power consumption to 80%. Lost 4fps and saved myself 80w in a demanding scenario (Control Native 4k Max RT settings).
Which block did you go for ? I have ordered the Active backplate version but apparently gets dispatched 18th for deliver 25th .... how come you are not just using the 4090 on air for the minute ?Still waiting on a waterblock for the 4090 FE
Ah nice another ABP user , i don't think they will do much at all for cooling but certainty do look much better and since i can't do a vertical mount on my setup will actually see the backside of the card more than the front so although a bit superficial i want it to look niceHad the regular FE waterblock on order from OcUK but ordered the ABP FE waterblock from EK.
Can't use the card on air as a) my system is hardline watercooling and I wouldn't want to disassemble b) I've got upgraded CPU, motherboard and RAM coming too which I'd have to re-do too![]()
I cant speak for others but personally swapping from a 3090 to a 4090 has cost me £600 , the big hit will be if you currently have nothing and want to buy a 4090 from scratch but i imagine most people will be upgrading and thus selling their old gpu to gain back some of the cost and depending on what you had previously will dictate how much extra you have to lay outI don't know if I'm impressed or concerned that people are happy to drop £2000 on a GPU.
Yeah but times have changed. Look at the price of the first iPhone, less than £400. Now people will happily drop over £1000 on an new iPhone without going the lengthy contract route.I don't know if I'm impressed or concerned that people are happy to drop £2000 on a GPU.
I cant speak for others but personally swapping from a 3090 to a 4090 has cost me £600 , the big hit will be if you currently have nothing and want to buy a 4090 from scratch but i imagine most people will be upgrading and thus selling their old gpu to gain back some of the cost and depending on what you had previously will dictate how much extra you have to lay out![]()
Kinda hard to tell, i dont find them offensive when they switch on.Can I ask, do your fans sound like this when they start spinning up?
personally i wold say yes its 100% worth the swap , it has given me the ability to run all the games i play at native 4k/120fps at max settings with more to spare if needed , i also play at 1440p on a 240hz monitor and again enough power to drive that at native fps to the point of the cpu becoming a bottle neck if uncapped. Performance uplift wise i am getting an 85% bump in performance at native 4k on SOTR compared to my old 3090 Strix ( which was no slouch! ) , i see a very similar gain in the rest of the games i play and that is without even touching DLSS , no regrets at all from meWorth the upgrade? I'm thinking of doing the same.
Which Zotac have you got?Zotaks almost always run about 30-40% fan so pretty much cant hear it either way!
Can just push a bit back on my TV stand though.I love this, but for a split second I thought you had no RAMAh nice another ABP user , i don't think they will do much at all for cooling but certainty do look much better and since i can't do a vertical mount on my setup will actually see the backside of the card more than the front so although a bit superficial i want it to look nice
A) Poor excuse , get that system drained and some new hard pipe bent as i had to
B) Although with all your new bits arriving i can understand why you would rather not but still an hours works and you can be playing on your new GPU now
No the ram is there just non rgb version, its the 8pack stuff from ocI love this, but for a split second I thought you had no RAM![]()
