Be aware the 3060 is in a completely different, MUCH lower performance category to the other 2 cards you mention. Of course, it should cost much less, although I'd argue that AMD has better cards in that price range than NVidia. Just make sure it's what you want if you get one.just noticed this takes 3 x 8 pin
is this standard on the 6900 xt
got around 500 to spend but only got a 750w power supply as was looking at a 3060 12gb or just found a 3080 12 gb for 750
would this be a better buy and would i need a better power supply
5800X3D should unlock a fair bit of performance for you in the future tooHi there, getting mine tomorrow, to replace my 5700xt, it`s paired with a 3700x for now until my wallet recovers.
my PSU is a super flower 750W 80 plus Gold, I hope it`s enough.
Yes that's the plan, just hope the 3700x isn`t too much of a bottelneck.5800X3D should unlock a fair bit of performance for you in the future too![]()
thanks for the replyBe aware the 3060 is in a completely different, MUCH lower performance category to the other 2 cards you mention. Of course, it should cost much less, although I'd argue that AMD has better cards in that price range than NVidia. Just make sure it's what you want if you get one.
The 308012GB & this 6900XT are much more comparable. You should check the manufacturer website & reviews for the specific model of card you're looking at. Power requirements can vary quite a bit between models compared to the own-brand cards by AMD & NVidia. Is your 750w power supply a good one ? And what CPU would you be pairing it with ?
You know that (user prefs or monitor customization aside) the 'image quality' of both AMD and nvidia GPUs is identical right? People use these things for professional photo/video editing etc. If they weren't identical, one or the other would be useless for professional applications.Having had a 3080, 3090 and 6900XT. I prefer the image quality of the 6900XT and it's very fast. I'd take that over a 3080 any day.
Hey - I don't want to lessen anyone's enjoyment of their hardware - I'm just stating that, logically, both nvidia and AMD have to produce the same image - there's standards for colour spaces (sRGB, Rec. 2020, DCI P-3 etc.) and software and hardware engineers on both teams dedicate a lot of effort towards ensuring what's generated by a PC (be it graphics, videos or games) is represented 100% to spec.I didn't know anything about the myth TBH. It's my own personal experience using different GPUs on the same monitor to play the same game. I can improve the Nvidia image by using the sharpen filter but that comes with a performance penalty. I'm not saying I wouldn't want an Nvidia card ( still have a 3090 for vr) I'm just saying I prefer the AMD image.
Its very tempting at this price. But i am a bit torn. Nice new gen (overpriced) gpu or fairly priced older gpu?????
Probably between this and 7900xtx, wont pay over 1K tho.
I have a 1080TI at the moment.)
Oh my signature was outdated. I've got a Platinum Asus 850W for this GPU - i) I was worried about transient spikes and ii) my old PSU was around 10 years old - so update was due anyway.Is your 750 watt psu ok with this GPU?
I have this also.
Had them for years. Never narrowed it down to the Vega 64 but I'm hoping this 6900xt makes life a little easier. Maybe my 650w PSU wasn't sufficient but I picked up an 850w as well just in case.Maybe time to get rid of the vega64. Hoping this will sort the ongoing issues with random game freezes and kicks to desktop or even pc resets. Did anyone else gets these issues? Here’s to hoping this sorts it![]()
Same I did upgrade my psu but problem still there. Hopefully we both become happier with our new beast.Had them for years. Never narrowed it down to the Vega 64 but I'm hoping this 6900xt makes life a little easier. Maybe my 650w PSU wasn't sufficient but I picked up an 850w as well just in case.
I think we'll have to agree to disagree on this one.Hey - I don't want to lessen anyone's enjoyment of their hardware - I'm just stating that, logically, both nvidia and AMD have to produce the same image - there's standards for colour spaces (sRGB, Rec. 2020, DCI P-3 etc.) and software and hardware engineers on both teams dedicate a lot of effort towards ensuring what's generated by a PC (be it graphics, videos or games) is represented 100% to spec.
That doesn't mean that there can't be rendering differences in 3D games between nvidia and AMD but if there are, it's typically a bug, not a feature.
AMD recommend an 850w for the standard model:thanks for the reply
power supply is a corsair HX 750W brand new I'm running a ryzen 5950x on an msi x570s ace max..
so I'm better spending a little more.. just read 3060 was good value but spending up to a 308012gb or this 6900xt would be a good step up.
So it this 6900xt at 649.00 good or am I better spending more for a 308012gb.
was just worried about 3x8 pin power. are most 3080's also 3 x 8 pin too
if so this card seems a good place for me to start
thanks
