- 27 Jul 2005
- The Orion Spur
4080ti?
Sorry, I had a derp moment, I meant 4090.
4080ti?
Toms hardware is reporting that U.S retailers got sold out within minutes
The actual board designs across the 3090 Ti, 4090 and 4080 are very similar (you could think of them as a v1.0, v1.1, v1.2) - also, all three cards use the same GDDR6X VRAM (the 4080 has a slower bus than the 3090 Ti/4090) - where the 40-series differs is in the silicon - it was fabbed on a smaller node than the 3090 Ti, can pack in way more transistors and has increased cache.Can someone explain to me eli5 why a 4080 is better than a 3090 even tho the 3090 has more memory and more cuda cores? Is it just clockspeed? Would an OC 3090 ti beat a 4080?
I'm talking about productivity/brute strength not just gaming fps
Clockspeed, cache and IPC.
Though it's not a major difference. There aren't many reviewers who put productivity benchmarks in their day one reviews but I did find a few benchmarks. I didn't see any where the 4080 is slower because it has less vram but that doesn't mean there won't be some outlier somewhere
And the result is that the 4080 is a little bit better than the 3090ti in productivity; it's not a major difference and if you can find a 3090to for cheaper than a 4080 then get the 3090ti unless you care that the 4080 uses 200w less than the 3090to and will reduce the power bill
The rtx4090 has more than double the 3080's VRAM and would you believe it, check out the benchmarks, it has more than double the performance too. Coincidence? I think not
16GB not enough.Yea but how? 24GB is more than 16GB?
You said this not so long ago?![]()
Sad, but true for the majority.
16GB not enough.![]()
I paid 650 MATE!.That is probably a true statement in his mind.
That said, who wants to pay around two grand for only 16GB? Should be 48GB for MOAR performance![]()
I paid 650 MATE!.
Talking about Grim, not you. Lol.
They should've packaged the 7900XT with 16GB of VRAM and released it as that 7800 XTX - maybe not for $599 but $799 tops. Like the 4080, it seems to exist solely to make the next card up look more attractive. Like Intel, AMD had a wide open goal this time round and flubbed it.Going to take a lot from AMD to get their mindshare back up. They should have gone more aggressive with pricing after Nvidia’s own goal imo. They just need to make a 3080 type card. For example they can release a 7800 XTX 16GB for $599 that has performance close to a 7900 XT which should be not be far off 4080 and certainly better than a 3090 Ti. Some will laugh, but I don’t think that is impossible or much to ask.
People only want AMD to be cheaper so Nvidia will drop their prices and then they will just go and buy an Nvidia card. AMD cant win.Going to take a lot from AMD to get their mindshare back up. They should have gone more aggressive with pricing after Nvidia’s own goal imo. They just need to make a 3080 type card. For example they can release a 7800 XTX 16GB for $599 that has performance close to a 7900 XT which should be not be far off 4080 and certainly better than a 3090 Ti. Some will laugh, but I don’t think that is impossible or much to ask.
Such card would give many people a reason to upgrade. They just need to get out of this we are a premium brand mindset. They won’t ever beat Nvidia like that unless they can consistently beat them in every metric and have the best card money can by for multiple generations, only then can they pull that off.
Just look at the CPU’s, they only started to up their prices once they actually dominated in everything. Now they lost their lead, but still want the high prices and no surprise their new CPU’s are not selling as well. They need to hurry and get the 3D Cache versions out as soon as possible and to take the lead again or their sales will get even worse as mindshare goes back to Intel.
