Yup, common issue.Anyone else had this error?
Was mid game (Warzone 2) in a duos. CPU at 51c and GPU at 60c. Screen just froze and crashed to desktop with this
Im on the 526.86 driver. Havent updated to 526.98 yet
I did a quick scan & repair then had 3 games that were fine.Yup, common issue.
Still must be a few issues if its common.
My fps tanks to around 5 still and had a ping of 6000 after 2-5 seconds of jumping out the plane.
I wonder of its some form if memory leak that’s linked to the game_ship.exe error
Happens to me in least half of the games, not sure what causes it. Got a friend with a 3080 and a 10900K that it happens to and one with a 8086K and 3080 that it doesn't. Guessing it's not VRAM related if it happens on a 3090tiMy fps tanks to around 5 still and had a ping of 6000 after 2-5 seconds of jumping out the plane.
A look online suggests it happens to AMD GPUs also so just some quality coding ?Only got it to level 6 so difficult to say, but as you said it’s just like every other AR tbh!No worries. What do you think of the gun?
Some nice low quality coding for it to crash on various hardware for no reason. Though its IT, so it will be for a reason.. turd codingHappens to me in least half of the games, not sure what causes it. Got a friend with a 3080 and a 10900K that it happens to and one with a 8086K and 3080 that it doesn't. Guessing it's not VRAM related if it happens on a 3090tiA look online suggests it happens to AMD GPUs also so just some quality coding ?
I had several crashes the other night, Switched of DLSS and switched it FidelityCAS or whatever its called. At least I could finish a game.Happens to me in least half of the games, not sure what causes it. Got a friend with a 3080 and a 10900K that it happens to and one with a 8086K and 3080 that it doesn't. Guessing it's not VRAM related if it happens on a 3090tiA look online suggests it happens to AMD GPUs also so just some quality coding ?
I've yet to try that. May give it a whirl and see what like. Fidelity looks sharp from a distance but close up and in certain areas, It looks very grainy.I'm running a 3070 (mobile) - I found that when I had maxed out the ASUS overclock settings in Amoury Crate (for base and memory clock offsets), even though the CPU and GPU temps were fine, it would crash mid-game. Nudging them down just slightly and they seem to have gone away... I've read the COD/WZ are quite sensitive to any overclocking.
Would be interesting to know what graphics/quality settings everyone is running with. Most of the youtubes seem to recommend FidelityCas FX for sharpening, but I found an article that compared the games visuals and the effect each setting had on FPS, and it recommended going with Intel XeSS, I've tried it and it does make quite a big difference to how the game looks, I just haven't decided whether I prefer it yet. I'm running with most things between normal and high and happy with FPS (100-120), very occasional drop in frame rate, but nothing major.
I just got thew exact same error in a game of trios when i was on 8 kills fairly early on. Only seems to happen when you're doing well ehIn the middle of a DMZ game with 2 others, doing quite well got a few dog tags and decent loot. Just exploring the police academy and we all got a "disconnected from steam" error at the same time. So annoying.
Yep just happened again in the middle of DMZ, bet I lose all my gear now too...Anyone else had this error?
It's the main reason I'm leaving DMZ for a while until they sort stability.Yep all good gear gone, weapon on a cooldown PLUS the key I found and was going to use all gone because the game keeps crashing. not good, not good at all.
Prefer this to the M4.I'm on now if anyone wants the M13B. Just add me in game, CliffyG78.
