- 30 Mar 2017
I still have that Bykski flow sensor. Need an excuse to use it on another project as it worked really well. Switched it out for the NEXT Flow that finally came into stock.Fitting the ABP has dropped my flow by quite a noticeable amount as was previously up at 180 l/h now 150 l/h , everything fitted correctly so just putting it down to the block being restrictive as temps are all good still... just tried with the pump on 1200rpm and ALARM started flashing on the byski sensor and the little spinning wheel was hardly moving , she definitely needs more pump speed to keep her happy![]()
