- 1 Oct 2020
Interesting chat. I've already stated I find myself quite sensitive to latency, so believe that I might find it to be an issue, but probably not until these cards are older - If you're starting at a base of around 100fps, it probably won't matter, but as time passes, it sounds like these cards will age more quickly, especially if frame generation generates more and more frames artificially to try and keep up. In other words, starting performance will be good, but once it starts deteriorating, it will deteriorate quickly if that makes sense.
The thing with latency is you can't tell by watching videos, not a true sensation at least - It definitely needs to be felt to be understood.
