Caporegime
- 8 Jan 2004
- Rutland
Several crashes for me tonight.
			Ok thanks for clarifying.No, it would have been sold when you extracted and you got XP from the cash.
Guessing you have a Nvidia card? The current crashes are specific to that brand.Last two games of DMZ both crashed literally within seconds of getting to the Exfil. One team mate disappeared early on too so looks like he crashed as well. Why so many many crashes?
Try redoing the shaders and turning off Reflex.
DMZ crashes will kill that game mode. I'm avoiding it until fixed.No I have an AMD card (6800 in sig), I know DMZ is supposedly still in beta but people are still getting regular crashes in Multiplayer too (usually during a mapchange for me - which is no big deal v a DMZ crash 20 minutes in when you are 30 seconds away from the Exfil which is understandably infuriating!).
I had several crashes in every game on WZ, Switched off DLSS and it seemed to sort it. At least I managed to finish a game with it off.I've not had crashes in Warzone 2 for some times now. Should I be aware of anything specific to DMZ as have never played it? Will give it a go to see if I have any issues.
There are bugs, but for me they only seem to be related to the benchmark when changing graphics settings (Dev errors and in game crashes to desktop which can be reported)
Those whos game crashes playing DMZ, does Warzone also crash?
I have all modes crash, including single player.I've not had crashes in Warzone 2 for some times now. Should I be aware of anything specific to DMZ as have never played it? Will give it a go to see if I have any issues.
event id14? Sure I had that years ago. I used DDU to remove nvidia drivers properly then installed driver only (no other geforce experience or anything) left GPU at stock settings, no undervolt or anything then it was fineI have all modes crash, including single player.
I've resorted to BF2042 until they figure out what it is and release a patch either for COD or NVIDIA to sort the issues as it's also causing some sort of memory leak in Windows causing my graphics card to become unresponsive at random intervals with errors like:
The description for Event ID 0 from source nvlddmkm cannot be found.
\Device\Video3
Resetting TDR occurred on GPUID:2b00
I may try DDU and fresh install also. I think the past few drivers updates, I didn't bother with DDU.event id14? Sure I had that years ago. I used DDU to remove nvidia drivers properly then installed driver only (no other geforce experience or anything) left GPU at stock settings, no undervolt or anything then it was fine
I don't think I've installed GFE for a long time now. Will give DDU a try.Certainly would recommend DDU and 527.37 driver.
Geforce experience caused issues for me in the past, at least I think it was that. Ran DDU and re-installed the same driver version without GFE and things worked.
I used it for a while in Warzone 1. Was great for capturing the last ~10 seconds when something good or funny happened. It did cause performance problems though as would sometimes jolt/stutter/hitch when recording on my 2080Ti. Maybe its different on my newer GPU but it still something else to throw into the mix to cause crashes or performance issuesI don't think I've installed GFE for a long time now. Will give DDU a try.
I think I used it for filters for a while then couldn't be bothered after a while. Like you say, Performance hit wasn't worth it.I used it for a while in Warzone 1. Was great for capturing the last ~10 seconds when something good or funny happened. It did cause performance problems though as would sometimes jolt/stutter/hitch when recording on my 2080Ti. Maybe its different on my newer GPU but it still something else to throw into the mix to cause crashes or performance issues
It's not unfortunately.event id14? Sure I had that years ago. I used DDU to remove nvidia drivers properly then installed driver only (no other geforce experience or anything) left GPU at stock settings, no undervolt or anything then it was fine
I had 1 game in DMZ. Had no idea what i was doing but found it interesting picking up random items like blow torches, jumper cables, computer parts and foodWhen you do get a good game in DMZ, it is absolutely fantastic. Sometimes it is impossible solo but when it does work out, it is incredible. Tremendous fun.
The crashes are far too regular and in DMZ you lose all your gear and everything too which is a killer.
I’d say less of a killer compared to Tarkov where your loot is valuable after you exfil - but probably a killer in terms of just not an enjoyable experience to know that you might crash at any time making the whole time a bit worthless.Is it really a killer ? DMZ is casual as hell, gear has no real value or worth and is incredibly easy to find, does anyone really care when they die or lose gear ?
