- 31 Jan 2022
- UK
Exactly. Had the Freesync one work exactly like the g-sync but with one less fan and firmware upgrade plus cheaper then it would be a no brainer. But that is not the case.
I would give it time for the dust to settle if you are concerned about any of the reports so far.
The 10bit HDR, I really see as exaggerated. The way that graphics cards get round the data rate problem is ingenious and really I for one can't see the difference. As for the flickering, I can't comment, I am using NVIDIA, but I am assuming that at some stage there will be a firmware update. Having said that, as I said before, I am waiting for someone to text the 7900xtx with F before I rush out and buy a new graphics card!
I am not sure about some of the comments about the user interface since it seems to have changed since Linus did his video. More info to follow, I guess...
