Gz Spellow! Glad you love it. Bodes well for meMine arrived and is running as I type.
Everything is fine!
Wow the colours on this and the contrast put the AW3821DW to shame.
One thing I have noticed, and perhaps this is an issue with Freesync(?), is that games no longer switch the refresh rate to the optimal for that game. Does that make sense? With my G-Sync monitor if I have the refresh rate set to 90Hz in the game settings then the monitor would automatically switch to 100Hz. With this monitor it doesn't do that. You have to ensure you are switched to 100Hz before you enter the game. Is that normal? It's no big deal but I am curious.
In passing, I am also confused about the settings in games. They often give a NITS setting in the game calibration, but this is often way out. Calibrating each game seems a bit hit and miss. I am not sure that everything needs this much calibration!!
Gah! Even the colours in Windows are lovely. I thought the AW38 was good but this is jaw dropping.
![Smile :) :)](/styles/default/xenforo/vbSmilies/Normal/smile.gif)
