Looks like they put in all the bells and whistles to look NEXT GEN!!!!!!!!!!!!! But because it runs like **** added in DLSS 3 to compensate
www.reddit.com
Yep, getting crashing on loading on the deck, I can get in game, but when trying to load a save it gives me the little animated scene before crashing.Anyone got this working on steam deck? Just crashes on loading. Plus was there really a need to add a launcher...
There's already a very simple settings guide:Wow, none of this performance feedback sounds good!
Without some optimisations it sounds like we need a settings guide to get the best balance between new visuals and at least 60fps performance.
Does hdr work?
You do not have to go back to legacy version. DX12 runs fine without RT and DX11 (in the updated version) also runs fine (and still allows ultra plus settings, and has the new features like paralax mapping in Novigrad).If your system isn't that then go back to the legacy version and add mods. It will look & run better.
I can't even sign into the red launcher, even though i have cyberpunk installed already, it should recognise my login, but it just jumps around the launcher and i can enter any details.
not a great experience on the deck so far
I can confirm it works with DX11, but you lose any options for FSR it seems. Would that be correct, FSR is only for DX12?Apparently you have to switch to DX11- not tried yet..
Yes but not adjustable atm. Looks fine as is tho imo.Was hoping you could tell me. Save me the hassle of checking myself![]()
You don't have to but it's better because of mod support. And no, DX 12 sans RT isn't fine because it also has a stutter problem but it's less severe than with RT enabled. Btw Ultra+ is just marketing nonsense for PC, the actual values are still far below the modded optimums which used to be properly unlocked in the game menu (with f.ex. "Tweaks" mod).You do not have to go back to legacy version. DX12 runs fine without RT and DX11 (in the updated version) also runs fine (and still allows ultra plus settings, and has the new features like paralax mapping in Novigrad).
Are you genuinely expecting a new release to immediately work on the Steam Deck?I can confirm it works with DX11, but you lose any options for FSR it seems. Would that be correct, FSR is only for DX12?
Not at all, that's half the fun in the deck, seeing what it's able run.Are you genuinely expecting a new release to immediately work on the Steam Deck?
Doesn't look like they bothered implementing it.Does hdr work?
Yes, Nvidia have rebranded DLSS 2 as DLSS 3 but without Frame Generation.Does it support DLSS2 for older cards?
A pity because the consoles have it.Doesn't look like they bothered implementing it.
Nah. Cyberpunk makes the 3080 look weak, but these 3 are just garbage efforts and mostly broken because of the devs/deadlines. Throwing more hardware at broken software won't fix it.With this, Portal RTX and the Callisto Protocol my 3080 is starting to look weak. What convenient timing for Nvidia.
I feel slightly sorry for those who grossly overpaid for the 30 series last year. Thankfully I got my 3080 FE for MSRP and it wasn't worth a penny more.
They did. Just turn it on in Windows and play.Doesn't look like they bothered implementing it.
