Palit probably has better cooling too
The Palit OC 3070 cooling was a mess.
FE Coolers 3xxx were pretty good. I would expect the 4xxx FE are too.
Unfortunately the FE is not sold in most countries; you can probably count on one hand how many countries where you have the option to buy FE
24 hours… I am counting the 12 days of Christmas and we are on the 5th day… If it’s still in stock, 6th day tomorrow hehe.Well UK is 1 as the 4080fe is still in stock.Not far off 24hrs too.
Another has joined ryder_1990 so there is some progress..
got an ax1000 i assume thats type 4If your corsair PSU is a type 4 you can fit one of these, fitted one to my corsair and a nice firm click when fitted, and direct to PSU no Octopus adapter needed.
https://www.overclockers.co.uk/corsair-pcie-5.0-12vhpwr-type-4-psu-power-cable-ca-272-cs.html
@Vertigo1 As mentioned previously the AX1600i was indeed overkill but out of interest how come you decided against the 4090 in the end ?
The 3080 used the top die though and was closer to the 90 in performance so it was a more premium card than the 4080.In hindsight nvidia will consider the 3080 msrp as a mistake and if the 3080 is going to be your measuring stick going forward, it’s gonna be one disappointment after another for future generations.
In the past couple weeks it's only been out of stock for one day.24 hours… I am counting the 12 days of Christmas and we are on the 5th day… If it’s still in stock, 6th day tomorrow hehe.
If they'd have priced the 4080 16gb at £950 instead of trying to con users into buying a 4070 (ti) under a different name (the 12gb) then I suspect people would have been a bit more willing to buy a 4080.. even more so if it got a drop to £899 with the £ improving against the $. Still a little higher than it should ideally be but it's the unfortunate situation of basically having nvidia as a monopoly on gpus.The 3080 used the top die though and was closer to the 90 in performance so it was a more premium card than the 4080.
If nvidia used the 102 for the 4080 then you could make the case of a grand being reasonable but with the 103 being quite a bit smaller and the 4080 not even using the full die I think a £700 price tag would have been dead on this time around.
There's been 'rumours' that Nvidia had been stockpiling stock to flood the market on release of the AMD cards, along with a price drop which hasn't happened.... could be partly down to that excess of stock too.In the past couple weeks it's only been out of stock for one day.
The 4080 12gb was a red herring product as it was so obviously bad it got the headlines but it's real job was to take the spotlight off from the equally poor but even higher margin 4080 16gb.If they'd have priced the 4080 16gb at £950 instead of trying to con users into buying a 4070 (ti) under a different name (the 12gb) then I suspect people would have been a bit more willing to buy a 4080.. even more so if it got a drop to £899 with the £ improving against the $. Still a little higher than it should ideally be but it's the unfortunate situation of basically having nvidia as a monopoly on gpus.
It doesn't help when Jenson has made it openly clear to the shareholders he's going to try and milk us this generation...
We are breaking records here.In the past couple weeks it's only been out of stock for one day.
Which screw holes did you strip to be able to mount the fan back?Love that. Finally got around to installing my waterblock on the fe 4090 and I knew the screws could be an issue but holyyyyyy I did not expect them to strip so easily…. Guess I’m sticking to air cooling this generation then… never had an issue putting a block on my 3080ti or 2080ti, but these were soft as anything and I genuinely don’t know what I could have done better.
