Going to return to this after not playing for months (think it was around May I stopped) so yeah, I'll have no idea what anything is or it does so will be off to the starting area to familiarise myself with the controls again.
Very similar loop. Much more open though and probably the best game they’ve made to date.How does this compare to the darksoul type games.
I could never really getting into the game play loop.
So I went back and completely cheesed commander Niall (branch of enchantment to take away his guard then cast my mimic tear after upgrading my bloodhound fang to +10) and he was down in moments.
I then pushed on to some other areas and beat the fire giant and the godskin duo and now midway through Farum Azula and after the godskin duo fight I’ve looked at the bosses ahead of me and I’m not sure I have it in me to go on and fight them…currently just over 62 hours in and I’ve had an absolute blast playing the game but from what I’ve read the bosses are exceptionally hard and uhm I just don’t think I want to put myself through that experience, maybe I’ll just return to other areas and beat up lowly enemies
I chuckled at your previous post, Niall can indeed be a piece of ****
I think you're doing great at 62h, even a bit too quick IMO. What level are you? BuffetSlayer is right, you can go explore a bit bit before you tackle endgame to level up. Your playtime indicates you're either very quick or have missed quite a lot of content (nothing wrong with that of course, just saying).
Have you been to the Volcano Manor and other big optional areas and completed Ranni's questline (too late for that if you haven't)?
Niall after 62 hours is pretty good going I reckon. After 100 hours or so I used a guide and went back to mop up the stuff I’d missed in the early parts of the game. I still haven’t completed everything after 150 hours or so. Need to go back as I’ve not played it in a while.
I played it on release on my PS5 and didn't find it too bad, but perhaps patches have made it worse in some ways ? I understand performance on the Series X is even worse ( lower and more variable frame rate than the PS5 ). Even on PC it's not that smooth ; great game but not a technical masterpiece.
).Yeah, I don't think I'm as sensitive to frame rate changes as some. But that tolerance is waning the more I play games on my 120Hz OLED and 166Hz monitor. I really struggle with playing Switch games these days, especially action oriented ones.No idea, my 2070S runs it a whole lot better, 60fps with all the stuff like grass on and very little pop-in in the entirety of Limgrave except parts of Mistwood and Moonlight Altar later on where the frames drop but still with less judder ( even with no VRR because I don't have a 55" 120hz Oled connected to my PC).
Here it borders on unplayable, I guess I'm just really sensitive to it but I can't believe some people don't notice something so jarring. I can notice momentary drops from 60 to even 58 but they don't bother me, what's happening here is often just bonkers.
XSX has slightly lower frames but it gets by with proper VRR implementation, on PS5 it barely makes a difference.
PS4 version runs great, better than I could make my PC run in problematic areas even with lowered settings but vegetation looks significantly worse and that makes the environments flatter. Then again, there's way less pop-in because PS5 grass just fades in a couple of steps in front of the player. That doesn't happen on PC. There are moments when it runs fine but they're far and in between.
It's a shame with locations looking this good but I guess I'm stuck with the PS4 version in my bedroom.
Yup, DF's recommendation was to play it on the Series X with one caveat - the player has a VRR capable display. Without it performance was worse than the PS5.I purposely chose the SX version over PS5, as DF indicated outside of PS4 version via PS5 this was the best way to play it. Running in performance mode, excluding the instant pop in of assets when fast travelling between graces, I think it runs excellently in my eyes. Thoroughly enjoying it and now trying to avoid using guides / walkthroughs, accepting I may miss NPCs, questlines or special items and just experiencing it for what it is. Just arrived at the academy and currently having fun falling off of rooftops![]()
