I might have missed this earlier in the thread, but I upgraded to Win 11 22H2 and have the white line at the top of the auto hide task bar, not the end of the world, but annoying.
I was also hiding desktop icons using the auto hotkey method.
I googled around to see if there was a solution to the white line at the top of the task bar and sure enough found people pointing to this utility (AutoHideDesktopIcons).
www.softwareok.com
This not only hides desktop icons (which when shown disappear after a timeout which you can set) but also will 'auto hide the taskbar' at the same time, and the way it hides it gets rid of the white line! Result!
Just thought I'd share in case it wasn't well known!
AutoHideDesktopIcons 6.51 Auto Hide Desktop Icons Portable Win-App.
Auto Hide Desktop Icons is a lightweight portable Windows program. If you use desktop backgrounds, it helps you to see sometimes the wallpapers clean!
