- 18 Oct 2002
- Aranyaprathet, Thailand
Interesting point about the limited tread depth on the Bridgestones. I need a tyre that can handle the power on the rears of a 380hp RWD car in rain as well as dry. My F is my daily driver so it gets used in all weathers and all road conditions. I don't rag it much because license but I'd rather be safe than sorry.Are you specifically looking for such a performance tyre?
Tyre Reviews “Overall - The Bridgestone Potenza Sport continues to be an exciting tyre to drive, with sporty handling and excellent dynamic properties in the dry and wet. This does compromise the aquaplaning ability, comfort levels and rolling resistance of the tyre, and as the only tyre with the starting tread depth below 7mm, this is a tyre for the enthusiast that prioritises driving enjoyment.”
Could be false economy due to the lower starting tread depth?
I just had a quick look on CamSkill and found 295/30/20 Hankook Ventus S1 Evo3 for £182.50 including VAT each, then fitting for example at Dexel is £12.50 a corner.
Tyre Reviews - Overall - The Hankook Ventus S1 Evo3 once again proves to be a tyre with extremely high levels of safety by having by far the shortest wet braking distance, short dry braking, and a safe understeer balance in handling. However having tested the Evo3 in the same test as the touring bias Bridgestone Turanza T005, the tyre feels dynamically closer to touring tyre than UHP tyre, so is one to pass on if you're looking for a sporty feeling drive.
Thats without the 5% Xmas discount applied.
