I had this with my series 6, I had to re connect the Apple Watch to my iPhone and that sorted it.Anyone?![]()
I re-paired it this morning but I'm still getting buzzes on my watch but no displayI had this with my series 6, I had to re connect the Apple Watch to my iPhone and that sorted it.
This isn't how it should be, right?No you should definitely be getting notifications on the watch and the screen lighting up, can you check the settings and make sure you have notifications set to push to the watch?I re-paired it this morning but I'm still getting buzzes on my watch but no displayThis isn't how it should be, right?
I get notifications, the watch buzzes fine but the screen only wakes when I lift my wrist or tap it. Then I see the notification.No you should definitely be getting notifications on the watch and the screen lighting up, can you check the settings and make sure you have notifications set to push to the watch?
Isn’t it £699 at Costco?Aaagh, temptation is too great. Very are doing their 10% back promotion which would make a new Apple Watch Ultra to be £764. I think the only reason I'm going for the high model is the longer battery life!!
All the ones I like the straps on are out of stock!Isn’t it £699 at Costco?
Which colour? And where from?That's done. I've watched YouTube, read reviews, from both casual runners and iron men/triathletes and they all loved the Apple Watch Ultra compared to other things like Garmin Fenix. So I went ahead and ordered one with the trail loop. Really looking forward to taking it for a whirl this coming week. Will also try out Apple Fitness+ and see how it compares to Peloton's workout app.
Never bought from Costco. Are they easy to deal with ?
As long as your a member (My brother is) you can order online, never had an issue with themCostco seems a bargain. It's a massive chunk off the price.
Even if you wanted another strap you could buy one and still come in less than RRP.
What did you getOh my days. This is marvellous. Feel a bit overwhelmed as there’s so much to do with it, wondering where to start!
I picked Mickey Mouse as the watch face. Reminds me when I had a Mickey watch as a kid.
What did you get
I'm moving from my S7 45mm to this, is that just a £5 fee ontop of you phone service for the eSimThe Ultra. Just coughed up the fiver pm for the cellular capability so should be all set for some exploring now.
