- 21 Jul 2005
- Officially least sunny location -Ronskistats
Some folk just can't get let it go, even after all this time.
"I must throw my anger and resentment towards someone else on the internet that has a different opinion to me, argh!"
However if you want to see an issue, you copy the settings used by said tech press which means you run at maximum settings. but if you want to test if 10GB (or 12GB) is enough and you want to validate the tech results, you use max settings.
Just tested Forspoken on my laptop (16GB of vram) and flickering textures aren't there.
Went back to my desktop and yeah textures do flicker or don't load properly.
The game seem to have some artificial limit on my 10GB 3080 as it doesn't seem to use more than 8GB of it and that is memory allocation and not actually used.
On my laptop it was using around 10GB of vram.
Same with the textures not loading, probably be fixed with a game patch, same way ubi fixed fc 6 texture rendering/loading.Most likely yea.Most likely a nvidia driver update will fix the flickering issue, similar thing happened with fc 6 on my 3080 10gb and a certain someone was adamant it was because not enough vram, fast forward to nvidia driver update and it was fixedSame with the textures not loading, probably be fixed with a game patch, same way ubi fixed fc 6 texture rendering/loading.
I've lost count of how many times I've said the same thing to you. If you want to talk to me, throwing insults is not going to encourage that. So yes, when I see you digging at me you can expect some sort of reaction back. Please don't act innocent and pretend you are not referring to me in your posts in this very discussion, it's daft and obvious. At least own it, don't make excuses. All I do is give you a little bit in return based on how you come across to me, as you like to say its only banter right.Must be - at least my posts are around actual facts - slinging rubbish like drinking - old, poor etc complete story telling - even ageist with the hate crime. Thought you'd be so woke being in big corp - maybe equality training not reached you yet.
But here 'tis;
If you want to see an issue and you wanna validate tech results.......................no - I wanna play the game - like 100% of gamers
Anyone else go around feeling the expertise in oneself must entitle them to be the tech press validating person?
If I want to test if 10/12GB is enough - I'll load up a tonne of mods, ones where I'd actually play the game - not validate tech press or then use the game as 10GB inst enough under tech press results - you are trying yourself in knots the more you type. This is what we were trying to say all along.
Lay off the name calling - I don't reply to you or directly use your name, all mine are based around facts. Like xmas day. Calling people old, forgetfiul, sad, drunk etc is just untrue. You know nothing about me. The age thing could go down as hate crime - I'd have thought in your corp you'd have been 'woked' right up around this.
Dunno why you get so mad when someone counters you. If you want to assume like usual I am referring to you then that is up to you. But I dont reply to you directly if I can as I know you'll get bent out of shape.
Just using the facts around the threads. Calling people sad and old is just childish. I'm older - but not old. And sad - well xmas day shenanigans puts that one to bed. If you can't counter with facts and reasoning - instead of saying things like drinking/sat in pants, old, forgetful, on benefits etc - none of which you can verify so is just name calling - just don't reply unless you can counter the debate with at least factuals in some way. Just makes yiou look triggered and your knickers so twisted they are irretrievable.
Now answer the question - why do I have to ask in other threads now? What's the difference? Answer here. Do you use motion blur - simple Y/N answer will do (or some reframing/avoidance tactic.
Wait wait what? That argument is a joke.You'll never see a 4080 faster than a 4090, but you will occasionally see an XTX faster than a 4090 in favourable titles.
Yeah, fair enough. It wasn't really an argument, but the point I was trying to make was that having used both the 7900 XTX and the 4090, I can see how close the XTX is to the 4090 in some things whereas the 4080 is not close to the 4090 in those situations, so the XTX is the faster GPU. I'll admit though, I was surprised to see it beating the 4080 in Dead Space Remake at 4K with RT on.Wait wait what? That argument is a joke.
You can see the 4070ti being faster than a 7900xt in favorable titles, but youll never see a 4070ti being faster than the 4080![]()
Yes, the XTX is close to the 4090 in some situations, but in some other situations it's closer to a 3090, or even below it. That's not a high end GPU I would spent money on. Of course that might be all driver issues, since the raw hardware is there, but I'm not buying hardware but performance. And let's not even talk about the RT performance which is abysmalYeah, fair enough. It wasn't really an argument, but the point I was trying to make was that having used both the 7900 XTX and the 4090, I can see how close the XTX is to the 4090 in some things whereas the 4080 is not close to the 4090 in those situations.
I'll politely disagree with you on the RT performance, as we can see from Dead Space Remake its faster than the 4080 with RT on. In other RT heavy games, Dying Light 2 for example, I'm actually quite surprised to find it beating my 3090 TI. Unless we count 3090 TI RT performance as abysmal now also.Yes, the XTX is close to the 4090 in some situations, but in some other situations it's closer to a 3090, or even below it. That's not a high end GPU I would spent money on. Of course that might be all driver issues, since the raw hardware is there, but I'm not buying hardware but performance. And let's not even talk about the RT performance which is abysmal
The RT performance is "good" on games that don't utilize RT mostly. I haven't checked Dead Space, but I assume it's the case, just like it is on FC6 / SOTR etc.I'll politely disagree with you on the RT performance, as we can see from Dead Space Remake its faster than the 4080 with RT on. In other RT heavy games, Dying Light 2 for example, I'm actually quite surprised to find it beating my 3090 TI. Unless we count 3090 TI RT performance as abysmal now also.
As promised, here is part 1 which is the intro part and the most demanding part of the game I've encountered so far. Once you take control of the character, FPS are 60-75 at 4K max settings with RT. Although the game pre-compiles the shaders before you load into the game, it does do some shader compiling at various points as you move around the world. Part 2 to follow...No one has shared this graph, but if you disable blurry DLSS/FSR and run native, the (power limited and throttling) XTX is actually 8%+ faster than the 4080 at 4K native with RT.
With an AIB XTX you can and will see much better numbers than that, I'll put a video up soon don't worry.![]()
That's not what I've found. Dying Light 2 RT was incredibly taxing on my 4090 and 3090 TI and the XTX delivers quite impressive performance there in comparison. Same for F1 2021/22 and the Callisto Protocol.The RT performance is "good" on games that don't utilize RT mostly. I haven't checked Dead Space, but I assume it's the case, just like it is on FC6 / SOTR etc.
And yes, the 3090ti / 3090 rt performance is abysmal for a 2022 high end GPU. That's 2 years old performance - literally. Imagine the 4090 having the raster performance of the 6900xt, and me saying "well is 6900xt abysmal in raster?"
Didn't you just say it offered same performance as the 3090ti? That's basically 2 years old worth of performance.That's not what I've found. Dying Light 2 RT was incredibly taxing on my 4090 and 3090 TI and the XTX delivers quite impressive performance there in comparison.
Yes in some less favourable titles, in some it's faster. 2nd Gen RT vs 2nd Gen RT its very close overall. The problem is AMD is a gen behind, but if anything 3090 TI level and lower is abysmal RT performance in your opinion then I'm okay with that. Just speaking from personal experiencing owning and using all these GPUs.Didn't you just say it offered same performance as the 3090ti? That's basically 2 years old worth of performance.
You think dying light 2 is one of the less favourable titles? Oh boy, the surprise when you try to run something like control 4k or cyberpunk 4k, you are looking at a 3080.Yes in some less favourable titles, in some it's faster. 2nd Gen RT vs 2nd Gen RT its very close overall. The problem is AMD is a gen behind, but if anything 3090 TI level and lower is abysmal RT performance in your opinion then I'm okay with that. Just speaking from personal experiencing owning and using all these GPUs.
