My first under screen one and it's pretty darn good, so much better than my wife's previous S20.How's the fingerprint sensor?
which phone and screen protector ? as the official samsung ones are supposed to be the best,Ive just tried to install the screen protector and ive had the same issues as everyone else line and a few bubbles,
could someone tell me if the lines or bubbles go away ?
the official Samsung, it is good but it has left 2 lines, im not sure what they are.which phone and screen protector ? as the official samsung ones are supposed to be the best,
just check the phone and the lines go away after a bit maybe the same will happen with the bubbles.I have got the Samsung screen protector on my S23 Ultra. Fitted myself. It's fine. Can hardly tell it's there.
To many drama queens on here complaining. Mine is fine. There's may not be.
Don't let them put you off.
How did you manage that? Or it arrived damaged?Just turned the phone on and the screen is already damaged.![]()
I dont think I did it, just turned it on after putting on the screen protector and the first thing I noticed was a 1cm wide line pink/green. ive been using it since and i don't notice it now.How did you manage that? Or it arrived damaged?
I I'm not sure because i never turned on the phone before the installing the screen protector so im not sureDamaged in what way? Not from the screen protector surely.![]()
I thought it was before I turned it on , but its the same line that change colour, like when a screen is damaged, but it could be the screen proctor after the line disappeared from the screen protector disappeared so did the line from the screen.Arent they the two lines from the screen protector? Not the actual screen itself?
I'm looking at it and I cant tell what happened, it looked it could be the screen protector but this is the first I've heard of this, looking at the images it was very noticeable, but after smoothing it out and using it for a bit, ive now gone back to a white screen and I cant notice itDamaged in what way? Not from the screen protector surely.![]()
I rang Samsung at 9:45 and to be honest the support is horrible, they wanted me to send photos which I did, after this another department needs to check them and tell me what will do and what will happen but I will/may need to send the phone back and then it would take 10 day for a replacement.Ouch thats rough, at least your within your right to return window, I wouldnt be wanting a repair, I'd be wanting a brand new replacement.
Im thinking the same now but is it normal to for the screen to do this ?that looks like its the screen protector
