I did have the massive wobbly at the sorting hat bit, but it seems like that’s standard for nearly everyone, regardless of setup.
That's illegal!Since I've turned off frame generation on my 4090 it's running beautiful now.
If you have either of the next gen consoles and have anything less than a 3080ti i suggest you get this on console lol thats if you want to play at 1440p, i was fine for the first 2 and a half hrs getting above 60fps, as soon as on the road to hogsmead fps went down to 25fps!
Was unplayable! luckily steam refunded me despite being over the 2hrs, its a real shame as i was absolutely LOVING this game, it is the best single player game emersion wise ive played since skyrim
My 3060TI is doing ok in 1440, 10 hours in now, besides, I'd rather cut my eyes out than desecrate myself with a console![]()
How do you flick between the potions in the bottom right of the hud.
Is this worth playing if you are not remotely interested in HP?
Guessing I have no chance of running this on the sitting room PC, which is a 3200G with 8GB RAM and a 1650 Super?
Kids are big HP fans and would love this game.
Thanks. Just remembered that it actually does have 16GB of RAM as I upgraded it recently. Will give it a try and if it's unplayable, pony up for a new build.Seeing quite a few reports of people losing progress/save files missing around 10-15 hours into the game which would suck if it is a general problem.
Minimum requirement is 16GB RAM and even on low settings it is using around 7.8GB or so IIRC. CPU and GPU would probably play it on low settings.
Think I'll pick up a charging station too getting really tired of cables littering the placeNoticed that other people's screenshots look more "crisp" than mine. See the hi-res screenshot thread where I posted a few. Am I missing a setting or something? Have everything on High or Ultra, plus DLSS set to quality.
If you're playing this properly (on a PCHow do you flick between the potions in the bottom right of the hud.
) hold 'tab' and move the mouse to select the potion you want. Once selected just tap 'tab' to use it.
Felt silly afterwards as the UI tells me what to do but it seem so unintuitive.Tried to play with a contoller last night and my combat went from poor to shocking. Pulled the contoller out mid fight, and went back to Keyboard and mouse.![]()
