4K- 240hz Ultra wide, yes pleaseCool, can can someone actually release an upgrade now like a 4k one.
4K- 240hz Ultra wide, yes pleasemaybe next year.
Ouch. That's a no from me, even if I didn't have the F already.
That's more than the Samsung basically, and even if you add HDMI 2.1, everything else is largely the same. I can't see how you could add more than what the Samsung did already and increase the price more than that.![]()
Indeed.So much for the $800 rumour price that was being flung around lol
I think most manufacturers send a refurbished unit unless it's within the initial cooling-off period. Bit of a shame.
but it has RGB to distract you, that's worth the extraEr, yes, that's not going to sell well then.
Average gamer will pay for a monitor but they aren't going to pay when there is a perfectly good Dell at 2/3 the price.
And you can't disable the RGB as an added featurebut it has RGB to distract you, that's worth the extra![]()
Wait... Is this confirmed? I didn't catch that anywhere as I did a quick look, but if that's the case...And you can't disable the RGB as an added feature
I was not being seriousWait... Is this confirmed? I didn't catch that anywhere as I did a quick look, but if that's the case...![]()
Side tracking a bit, but yeah, we did that here with the BT Smart Hub 1, as we're using it as an extender and thus the LED keeps blinking about no connection (as it's software demands it to to notify users of no connection). We've turned it to down to the lowest setting but it still blinks the place to disco heaven. So we taped the entire LED up in black tape. When will manufacturers learn?Out with the black sticky tape then!
.. I have actually done that before with some RGB devices![]()
The AW3423DWF can be had for £812.36 on sale today, which is a decent saving on this model but it asks the question as too why? Good deal?, Is there any issues with them? or is there something new on the horizon (no zero dawns) from Dell?
I think most players should be OK.Yes forum users correct me if I'm wrong but if the game goes below 60fps you don't have the gsync smoothing plus with oleds you get flicker below 60 so combined with the two of those issues then not a good experience at all.
Would have liked to have grabbed it at the cheaper price now, but to be honest, I'm still super happy at getting a display that was so flawless on first go. Especially with some of the horror stories of failed QC and getting fans that are louder than your GPU, and screens all smudged up or a panel that's got quite a few stuck pixels.The AW3423DWF can be had for £812.36 on sale today, which is a decent saving on this model but it asks the question as too why? Good deal?, Is there any issues with them? or is there something new on the horizon (no zero dawns) from Dell?
