The Last of Us Remake | March 28th 2023
  • Thread starter Thread starter mrk
  • Start date Start date
Disabled DLSS?
Also, bit lol:
my only problem now is it takes 5 mintes+ to load a save game
CPU? SATA SSD or NVMe? Seems those on a SATA SSD are seeing longer load times and shader comp. Doesn't make sense since even on an NVMe SSD, the read speed during load is under 200MB/s lol.
@mrk sorry if you have posted this before but are you able to list your full system specs and what if any undervolt / overclocking you have on CPU/Memory/GPU?
Sure it's:
- Gigabyte Z690 Gaming X
- 12700KF (stock)
- 64GB DDR4 3600MHz (CL18)
- RTX 3080 Ti FE (only power limited to 90% in MSI Afterburner)
- 2TB Sabrent Rocket 4 Plus-G
- Alienware AW3423DW @ 144Hz Gsync (3440x1440)
It's not the game folks, it's just your hardware at fault, simply ain't good enough..... right @Woodsta888 @TNA :D :cry:
Yep, must be hardware - nothing to do with the game - reviews confirm. Though I'm confused whether they are reviwing the game on steam or gfx cards, particularly VRAM amounts
  • Recommended:
    • Requires a 64-bit processor and operating system
    • OS: Windows 10 (Version 1909 or Newer)
    • Processor: AMD Ryzen 5 3600X, Intel Core i7-8700
    • Memory: 16 GB RAM
    • Graphics: AMD Radeon RX 5700 XT (8 GB), AMD Radeon RX 6600 XT (8 GB), NVIDIA GeForce RTX 2070 SUPER (8 GB), NVIDIA GeForce RTX 3060 (8 GB)
    • Storage: 100 GB available space
    • Additional Notes: SSD Recommended
Reccomendations are just wrong, 10 yr old remaster must've been designed for a 6090 - a game for 2 gens time.
6000+ game owners = 6000+ 4090 sales.
How well is DLSS 3 implemented for 4080/4090 cards ?
In MSFS2020 the gains from it are absolutely ridiculous, 80-90fps boost
GAme dependant really same as RT implementation. Not only DLSS 3 (DLSS2 was good on last gen too) but on 4000 series cards you have frame generation also. Your figures for MSFS may include DLSS + FG.
I'm running it on a 3060ti, getting about 20 minutes at a time before it crashes. Sometimes it'll last longer if I reduce the graphics setting to LOW, but it's a trade off between decent graphics and Joel looking like a lego man.
Must've borrowed FC6 release textures, like the lego crocodile. Never mind, an HD texture pack will be applied as a fix, like a mod - will use up VRAM.
