Nice! Didn't realiseAssassin's Creed Valhalla, Metro Exodus, Deathloop, The Spiderman games, Sackboy, Uncharted Legacy of Thieves, A Plague Tale Requiem, all support the PS5 pad, and more.
Disable it, that will likely fix the crash issue, it did for me and others.@mrk DLSS is enabled.
And wow that CPU usage.
If it crashes again will definitely try disabling it.Disable it, that will likely fix the crash issue, it did for me and others.
CPU? SATA SSD or NVMe? Seems those on a SATA SSD are seeing longer load times and shader comp. Doesn't make sense since even on an NVMe SSD, the read speed during load is under 200MB/s lol.my only problem now is it takes 5 mintes+ to load a save game
Sure it's:@mrk sorry if you have posted this before but are you able to list your full system specs and what if any undervolt / overclocking you have on CPU/Memory/GPU?
It's not the game folks, it's just your hardware at fault, simply ain't good enough..... right @Woodsta888 @TNA![]()
How well is DLSS 3 implemented for 4080/4090 cards ?
In MSFS2020 the gains from it are absolutely ridiculous, 80-90fps boost
No DLSS3 in this game (aka fake frames) only DLSS2.How well is DLSS 3 implemented for 4080/4090 cards ?
I'm running it on a 3060ti, getting about 20 minutes at a time before it crashes. Sometimes it'll last longer if I reduce the graphics setting to LOW, but it's a trade off between decent graphics and Joel looking like a lego man.
