Again, I respectfully disagreeIf the Audi had got its nose at least alongside the rear tyre there might be an argument but the Audi at no point ever has any part of the car alongside the Aston... apart from when they make contact and even then it’s not got it’s nose alongside the rear tyres, it literally just clips the back of the car.
It’s just a minor screw up from the Audi with an unfortunate outcome
Yes, I was interested to see what other people thought of the incident. That doesn't mean I can't disagree and explain why I hold that opinion.
Here's why: It wasn't an overtaking attempt or even a minor late braking divebomb. The only reason he got that close is because the two cars ahead were battling.
The Audi brakes at the 100m board, which is the normal point. The racing line is clear, as the Aston has gone wide due to the BMW overtaking on the inside.
Look at the pedal and steering inputs and tell me honestly how it could be seen as an aggressive move or how he should have had the clairvoyance to anticipate what the Aston did. If you could also explain why the Aston has zero responsibility here, I'd be interested to hear that too.
the car behind has the greater responsibility to avoid unnecessary contact in that scenario. Especially when you consider the car in front had stayed wide to avoid contact with the first car through the initial stage of the corner.
Is that what you think happened here?expect the cars behind to chance it with some unholy vow of entitlement.
